Shorter cranks on both bikes?162.5mm compared to 172.5mm
I have recently made the transition to shorter cranks on my TT bike to great effect. My N=1 observations are more comfort at higher efforts due to decreased hip angle, which helps massively with my breathing. I no longer feel as restricted. I have also set PRs on the run at all races since swapping, but this may well be down to consistent training and a decent taper for my last A race.
Now the off-season is nearly here, I am planning on settling the TT bike onto the trainer until next year. I will still do rides outside when weather permits on the road bike.
I went from 172.5mm to 162.5mm and still run 172.5mm on the road bike. I was wondering if anyone had any opinions on whether it would be more beneficial to swap over the road bike or keep as is. I can certainly feel the difference between the 2, but don’t mind either. However, if there is a tangible benefit to going shorter on both, I am in.
Thanks
Longer cranks on the road bike than on the TT bike can maintain a more similar minimum hip angle between the two bikes. So I recommend you keep your longer cranks on the road bike.
There’s mention of this idea (and others) here:
http://www.cervelo.com/en/engineering/ask-the-engineers/crank-length.html
Cheers,
http://www.cervelo.com/...rs/crank-length.html
Cheers,
Damon,
Thanks for that, makes perfect sense. I had stumbled across that article when researching shorter cranks, but your statement makes it very clear.
Cheers
Hi Damon,
can you confirm the crank length on the P5 51? is it 167.5 mm?
thanks
