Seems that the fork isn’t true…(The nose cone isn’t centered).
I tried 2 different wheels and same thing.
Can you confirm?
Can you confirm?
It look like your aerobars aren’t aligned. Loosen them up, align them, and then torque the bolts back down with a torque wrench. That’s the problem with carbon stuff…things tend to shift from time to time, especially aerobars.
I’m looking at the outer most edges of the nose cone and the RHS (top of the photo) is definitely sitting wider relative to the fork (and wheel) than the LHS (bottom of the photo) - assuming you took the photo vertically from the bike. I know nothing about the Shiv front end - I assume it is not possible to adjust the cone/headstem relative to the fork as per a standard fork/headstem assembly?
I have the same issue, my L extension is inward (compared to the R)…I asked my LBS and they checked with Specialized if this was a warranty issue and they said it is not covered.
There is more adjustment in the front end than you think. You can adjust the aerobars a bit, the nosecone a bit, etc. Best to make sure everything is aligned at each step of the build.
