Selle SMP Strike Pro - Feedback
I have been on a quest to find a new saddle that is more comfortable and can be used for both road and tri riding. My riding style is fairly ‘non’ aggressive. I typically sit back on my sit bones, and don’t ride up on the nose of the saddle. Having tried a Selle Italia, Cervelo, and Arione - I finally broke down and ordered a Selle SMP Strike Pro.
http://www.sellesmp.com/download/Saddle_SMP_Strike_GB.pdf
Aside from the crazy design and expense ($220 US), I rationalized the purchase knowing that my ‘boys’ would theoretically be better off with the cut out, thus preserving their important function. I have done two trainer rides so far and have been very pleased with the feel (absolutely no pressure ‘underneath’). Because of the cutout, it seems to take a little getting used to (being a tad wider through the middle of the saddle and rubbing a little bit on the inner thighs). I plan on doing a few 1-2 hour trainer rides this week to determine if I will keep it or return it. Does anyone else have feedback on the Selle SMP saddles?
I have tried numerous saddles in an effort to find one that didn’t squash my soft tissue to the point of numbness followed by excruciating pain (I am female, so slight anatomical differences exist). After an hour or so on the bike, in an attempt to relieve the pain, I would rotate my pelvis back to sit more on my butt. This resulted in neck and trap tightness also.
I purchased the SMP Evolution and all my problems have been solved. I love it. Since it has little padding, my sit bones get sore but I’ll take sore booty over crotch on fire any day. I haven’t tried it on my TT bike, so not sure how it will work in an aero position. So far, worth every penny…all 20000 of them!
Used the SMP Strike Plus all last season on my road bike, love it. As long as I have a road bike it will have one on it unless something significantly better comes along. Takes a ride or three to get the sit bones used to actually being sat on but then it’s comfy. I don’t know if it would do as well on a tri bike, not much padding on the nose and the nose dives down pretty sharply, I’m considering trying an Adamo for my Dual.
I got the SMP Evolution. That thing really works, no numbness at all. It is a little hard and so it took a few ride to get used to that, but again no numbness. I too use it on my road bike. I got a great deal on it. The Performance Bike in Chapel Hill, NC has a clearance room and they had a few of them at 40% off. I think I paid something like $160 for it. Still pricey, but worth it to me.
Peace,
Rob
Thanks for all the feedback.
I am wondering if the selle smp strike “glider” at 136mm wide would reduce some of the rubbing on my inner thighs and perhaps be a little more comfortable vs. the selle smp strike ‘pro’ at 148mm wide? Or would I even notice the difference. I dont want to give up much padding in the back, as I need to be able to endure longer IM rides this year…
Any thoughts?
Who has had this on a tri-position? Comfort? I’m deciding between this and the Fizik Arione tri…
cyclonehockey21 is the only one I know who has extended time on a Strike saddle (the Evolution model in his case) in the aero position. He speaks very highly of it.
The only real worry I have with this design in the ability (or lack thereof) to move around on the saddle for varying terrain, comfort, etc. If a saddle only has one comfortable position, no matter how comfortable that position may be, I’m not sure it’ll work too well at longer distances - especially if that distance includes a variety of terrain.
FWIW, there are a few saddles that I’d like to try, and this one is at the top of the list. The others are the Adamo, the Specialized Toupe and the Selle Italia SLR.
What I’ve found with my saddle experimenting thus far is that I like a very narrow nose and don’t require a lot of padding. I’m currently on an Arione (road version) and have tried the Selle Italia SLR T-1, the Profile Design Tri-Stryke and the Arione Tri. (I ride the nose, BTW.) I don’t have any major complaints about my current Arione, but I always wonder if there is something more comfortable out there.
Steve
I like the SLR, but the wings dig into my hamstrings. I’ve been on the Balckwell Flow. I can use several different positions and the rear is very narrow, so no ham dig. Not for everyone, though.
BTW, I only sit centered on it when at the rear. Otherwise, when I’m in the middle and on the nose, I’m to the side, like when I use an Arione and SLR.
Using the Strike Evolution on my tri-bike. Works as advertised; I’m able to setup the bike with a lot of drop between the saddle and bars and the anatomy falls right into place without pressure. The Evolution is 129mm wide and I have no thigh rubbing issues, whatsoever. Although the saddle is great in this application, it’s my opinion that it wouldn’t be so good in a conventional road position. When viewed from the side, these saddles have a very curvy profile, and when combined with the minimal padding makes for a lot of pressure on the sit bones.
Haha, i should get sponsered by selle and swimp3 with how much i get asked abotu them :slight_smile:
I put this seat on my race bike and ordered anohter one for the trainer i am building up. I’ve used the one for around 300 miles or so and i have to say it works great. I’m not always in the tri position inside just because its a lot harder to sit it in especially with how much drop i have, with out actually moving.
Depending on where you sit on it and how much drop you have it may or may not be comfortable. For me i sit further forward on the saddle which makes where it drops off in the perfect spot. The cavity between the rails is also very beneficial if you are down in aero you can look back and actually see that pressure is being relieved there. Hopefully that is understandable without being too descriptive.
The only real con i have from it is you do have to get used to the sides. I have the evolution and there is not a lot of padding there is a bit but if you are looking for more comfort i would get teh stratos or glider. Because of where they hit your but has to get used to it. However my theory behind the thing is i’d rather have my butt have to get used to it then cutting off circulation down there.
If there are any other specific questions let me know.
Grant
On my last trainer ride I rode in the aero position for a while, with no pressure at all. I was surprised how comfortable being aero was on the Selle SMP…
I have the SMP strike stratos. I use it on my road bike and like it. No junk pressure.
Anymore feedback from anyone with this SMP Strike in aero position?
just rode 30mins outside with it today and it worked great. i had it tilted down way to far though so i was holding myself up with my arms but thats just an adjustment issue.
Grant
I love mine!!
That’s an amazing signature… haha.
This is becoming a common question on the board, and the replies have mirrored what we’ve found. We carry the entire line as test saddles, allowing customers to check them out on their bikes before purchasing. The saddle simply disappears underneath you, with the exception of the pelvic bones, where the saddle forces you to sit (you know, where you’re suppose to be sitting in the first place!). Just be prepared to feel only your pelvic bones! It’s a very different feeling. It takes only a few rides to get used to the new sensation and, after that, you’re in comfort city.
I initially brought the saddles in for our lady customers, but quickly found men benefit from them as well. The saddle library is always checked out, and we have a waiting list which grows daily. Now, here’s the rub (which has also been mentioned in the responses). The saddles all have their unique differences, and it really helps to try them before you plunk down the $220+. Problem is, not many shops have them, but if your shop does happen to carry Selle SMP, mention that there are “Test” saddles offered at reduced pricing from the distributer - perhaps that will encourage them to establish a saddle library themselves.
They make great road saddles, by the way. It’s actually just by chance that they work in the aero position as they weren’t designed for that purpose. Seel SMP’s brochures actully allude to their use as mtb saddles. There is definitely a “sweet spot,” and baby it is oh so sweet- though, as you become accustomed to them, you find there is some wiggle room, just not much. Then again, a lot of people move around on their saddles more for comfort than anything else - they just don’t realize that’s the reason. Either way, it helps to try one first, even if it’s just on a fit bike at a shop.
Oh, and get your hands on a brochure if you can - it’s hilarious in it’s lack of, shall we say, “tact” when it comes to describing what area the saddle’s shape relieves.
