I bought a bare frame off eBay recently (MTB frame). I measured the opening of the seat tube at 31.2mm (inside diameter) and 34.8mm (outside diameter). I’ve seen 31.6mm and 30.9mm diameter seatposts (and everything else all over the map). I’m thinking I should be using the 30.9mm seatpost. Is this correct? and will standard seatpost binders work on this frame?
Thanks!
