Seatpost bottle cage for Cervelo Dual?
Has anyone installed a behind the seat bottle cage on the Dual aero seatpost? Doesn’t look like the cylindrical part at the top (~1cm) is wide enough to fit a bottle cage collar.
Any suggestions?
Xlab solves those problems. It has four screws that hook onto the saddle itself.
I use the Minoura Cage Mount on my Soloist Team
http://www.all3sports.com/product_info.php?pName=minoura-cage-mount-complete-deal&cName=accessories-hydration
Hey,
I just read that those bottles behind the saddle habe negative results on your aerodynamics. The air cannot stream past your back.
Anyway, I own the Dual and don’t have a clue where to put them instead.
But I saw the CSC team riding with Camelbaks under their shirts. Has anybody an idea how they do it??
Hey,
I just read that those bottles behind the saddle habe negative results on your aerodynamics. The air cannot stream past your back…
You mean the 1.5 minute difference on a 112 mile ride?
http://www.slowtwitch.com/mainheadings/techctr/waterbottles.html
At 6’3’ and 195 on a 58" Dual, I think the increased drag coefficient associated with seat mount water bottles are the lesser of my worries. These studies are certainly informative for pros in wind tunnels, but for mere mortals like myself…
Thanks everyone for your suggestions for other water bottle mounting options !
My wife uses a Minoura on her P2K. Should work on the Dual.
I also use the Minoura cage mount on my dual. I tried the XLab, but it didn’t fit behind my Fizik Arione saddle (it’s longer than most saddles).
-Bam Bam
Minoura it is. Just ordered one on all3sports. Thanks again.
jude
I use a minoura for long training rides but racing I prefer a profile or similar between the aerobars. May have an aero advantage but mainly find I drink more with the bottle/straw so handy. Never had a problem refilling on the go and don’t mind the gatorade usually available at feeding stations.
Peter
Thats a good point there, K. Thanks
i have the xlab on my dual and it works great! Good luck
I realized yesterday that I’m going to need to do something similar for my P2K. The seat tube only bottle is a major pain to reach when aero. I’m thinking the Minoura above would be great, and then you just dump the bottle into an aero bottle up front.
