Seat Post Blues!
OK, I’m one of these heavy sweaters (not like wool or knit, like raining on the guy behind me in the pace line). And I’ve had seat posts seize up on me before, but that was on my old metal Stumpjumper with an alu seat post. I hadn’t adjusted that seat in years, and with all the mud and sweat it took hacking off the seat post and using all kinds of tools to pry that puppy out.
But now my seat post is stuck on my Litespeed. Any remedies out there to loosen up the corrosion of my toxic sweat around the seat post clamp??? I would not have thought it would do this on a titanium bike, and I have adjusted this post height within the last 12 months??
Come on! I know some of you wrenches can offer a suggestion.
spray some WD-40 around it and let sit overnight. Turn the bike over and put the post in a vise, and turn the bike until it breaks free.
WD-40 does not work on aluminum, just on the titanium. If it does not work, use some amonia and wait a while. After that start twisting the sadle.
Try enlarging the ears of the seat tube with a screw driver or those inverted plyers.
If nothing else works, the final resort is to cut the seatpost off. Leave 1" sticking out then insert a hacksaw blade into the seatpost and carefully cut it in half, verticaly. For an aluminium seatpost it will take a lot of work and patience not to damage the frame. After cuting the tube get some plyers and roll in the tube.
good luck
I have heard of using a hair-dryer to warm up the frame and then cooling the seat-post such as by spraying a co2 cartridge on it. The theory being that you expand the frame and contract the post. I have never tried it.
get some PB-blaster. It’s penetrating oil with a anti-corrosive agent. WD-40 is meant to displace water, not penetrate and not lubricate. I’ve used this gunk to free up exhaust and suspension bolts on my truck. If it can break through that sort of crap, it will probably do a fairly good job on a suck seat post.
Get out the propane torch and heat the seat tube (gently) and pull on teh post (assuming that the post is metal).
You’ve got an interesting conundrum. Litespeed’s come with an aluminum insert in the seattube according to Herbert. Search around on weightweenies.starbike.com for “seize” “ti” “litespeed”, you get the idea.
Dude, that is exactly how I finally dislodged the seat post on the mtn bike. I’m hoping not to have to do that on my Litespeed. But it may come to that. Thanks!
vortmax, I assume that is the name brand?? Would I find it at an auto parts store??
yep, any auto parts shop should have it and it is called “PB blaster”. Make sure you do it in the garage and don’t get your face anywhere near the stuff.
Just give it a good spray around the base, let it soak in for a few minutes, spray it again and let it sit for an hour or so to soak in. It’s designed to wick it’s way into corroded threads, so it needs some time to work its way in. If it’s a long seat post, you might want to spray and wait a few times.
how do you prevent the post from seizing? cleaning it regularly? have a thompson post on my litespeed…
Simple, use anti-seize compound when installing.
