Scott Plasma 6 disc Carbon
https://www.facebook.com/TriRig/posts/2887566241270005
Looks like Cervelo for the mono post.
Agreed. Such a large gap. Plus the loss of the front hydration leaves two very large gaps before you get to the cranks
Would you still say that of the gap makes it faster?
Also, it has integrated hydration. Look for the straw in the picture
Does anyone know what happened with this bike?
No signs of release…
More sites are starting to list it, mostly European ones.
This one says 1-2 day delivery, which I’m not sure I believe.
https://www.winterparkcycles.com/plasma-premium.html?id=53747856&quantity=1
$15,000 plus tax lol. They gonna pull a specialized and essentially stop making consumer tri bikes?
Or “pull” what every manufacturer does, which is start with top spec and then work down.
Without going back to reread the threads, I think there was mention of an Ultegra Di2 version around $8000. Seems aligned with Cervelo and other brands’ pricing.
What’s more shocking is something like a $7,650 “sale” price on a super basic Quintana Roo with Ultegra Di2, Shimano training wheels, and a basic aftermarket cockpit.
https://www.winterparkcycles.com/...47856&quantity=1
Goodness, they’ve gone backward.
They are one of the first who managed to hide most shifter and brake cables, back in 2010 with the Plasma 3 TT
Ten years later, they still got brake cables dangling? SMH…
I think that is a drinking system straw you see - not a brake cable.
But also - I just don’t see how this thing can be for sale, when it isn’t even on the Scott website.
And no athletes are getting this bike and posting pics on social media?
I just don’t see it … Seems sort of fake.
I hear ya. But the new specialized shiv has been out for almost 2 years? And they haven’t worked down yet 😂
Complaining about the cost of a $7600 bike in a thread about a bike that costs 2x that?? Lol.
At least the QR has trickled down and you can get a full disc brake bike for less than$3k from them.
It just seems that brands aren’t really trickling down. Specialized is still expensive. Cervelo P3X still expensive. I doubt this Scott is going to trickle down. Maybe to $10k??
Where do you see the brake cables other then at the fork and chain stay where they enter the brake caliper.
And even there they seem to be ‘hidden’ by the design.
Jeroen
Ultegra Di2 Version - $8999 - MSRP
https://cdn.shoplightspeed.com/shops/605241/files/25089805/scott-plasma-rc.jpg
Ah yes, you are right. I didn’t look as carefully and thought it looked like two separate cables, whereas it’s just the drinking tube.
Yes and I would also complain about a $50k Corolla hatchback in a thread about a $100k 911 S. They’re not even the same spec.
The sale-priced $7600 QR is a non-superbike with training wheels and FSA cranks while the $8999 retail-priced Plasma has carbon wheels and Ultegra cranks. The fact that retail on that QR if $8,500 is hilarious. That’s $500 more than a Di2 P5 or P3x
The Specialized, P3X, and Plasma will never trickle down to $3k because they aren’t simple double triangle bikes with standard cockpits. We’ll be lucky to see them around $5k, which will probably happen once they are many years old. They aren’t in the same league as QR, which is more like a P-series or Plasma 10. For reference the P-series Di2 retails for $2000 less than the PRsix2 and is better equipped.
xOld discussion but will post anyway. Got few months back Scott Plasma 6 RC with new Zipp 808 NSW. unbelievable smooth and fast riding machine! No wonder triathlete.com gave it 5 starts and called best tested Tri bike so far they tested https://www.triathlete.com/...rc-6-triathlon-bike/
IMG_4470.jp2
Wow!
Canyon keeps delaying release of CFR in USA.
Now this!! ;-D
From info I can gather, and seeing Keinle this weekend I’m more than interested. Can you comment on bar tilt. they have listed as 15 degrees on Plasma 6 , that with tilt wedge(tri rig) I would be able to replicate mantis position i now have. Which does not appear possible on CFR with max tilt of 10 degrees and perceived limitations of mono post?
Thanks
David
I also was watching Speedmax release in US, specifically CF SLR. Hasn’t happened and I needed a bike for June races. No regrets with Scott Plasma 6!
I feel very comfortable with aerobars tilt as it shows on the pic. I believe you can make angle even bigger with the accessories included (Scott animation at this URL shows how it changes https://www.scott-sports.com/us/en/plasma-6) but not sure what the max is to be honest. Also note that at this Scott page aerobars they show are more flat compared with ones on my bike. With my aerobars version you can get bigger angle if that is what you need (i think i have “Extension E2” in oppose “Extension E1” as shown at Scott Syncros page: https://www.syncros.com/...ad-triathlon-cockpit…)
But I agree, the tilt ability on this bike is definitely bigger than on Speedmax…
Hope this helps
Alex
Alex :
Is there room above bottom bracket to mount aero bottle on downtube??? How’s the refilling on the fly of the intergrated bladder?
Have located a bike. … sigh … why is it always hard to pull the trigger??
paralysis by analysis :smiley:
Again THANKS in Advance
David
Yes you can put water bottle on down tube, there are screws to mount the cage. However, if you do that you will not be able to leverage above the bottom bracket gel container. The cage would block it. Frankly if you use integrated bladder (650 ml) and two behind the seat cages, you don’t need the forth on the down tube…
As for refill on the fly, Flap the cover and the opening is big enough so you can squeeze the bottle to fill it up without spilling around. Canyon Speedmax CFR has a valve instead but probably you would need to be more precise to discharge the bottle into the bladder.
my two cents :slight_smile:
