I used to love my Quarq. I’ve had it ob my P3 since 2011. It’s been sent back to them 5 times now, once per year and twice this year. Next time I’ll replace it with the Garmin. No more Quarqs.
It’s good to see the newer quarq models but I have a question: say I decide to buy one of the newer quarqs with 170 cranks. If I want to switch to a different crank length (say 165), would it be possible? Or are you stuck with the same crank length once you purchase it?
My experience has been IF a shorter crank version exists, Quarq will do the swap for the price of a new crank. But there are models, such as the Rikken that do not have anything shorter than 170. If you start at 175 you could have them swap it to 170 eventually. You can do it yourself as well.
Cool. So basically if I have the crank arms that I need the quarq to run with, I can swap them myself without needing to send the unit to quarq. That’s pretty much the same case with P2M too, right?
I don’t know about P2M.
Quarq sent me the instructions to do it myself (for a Rikken). However, Quarq will do it for you and I believe the charge is only for the new crank.
Rob will probably be able to confirm.
BTW, another person here that has had amazing service from Quarq. It’s when you are a few days from a race and your PM does something funky that you truly appreciate the value of their service.
Which crank do you currently have? I think Power2Max does it with at least Rotor arms and maybe a few others that have removable spiders in their design.
just curious which PM you are getting now after your trouble with quarqs?
Yup, P2M does it with those that have a removable spider. I currently run the old Rival cranks (no removable spider. the newer Rival 22 have a detachable spider I believe). I know I can’t use these cranks with either of p2m or quarq but one requirement for me is the flexibility in being able to swap crank arms without needing the unit to be sent back to the manufacturer. But it looks like quarq will do this too. Nice. Thanks guys.
If my Quarq fails again for any reason, my local bike shop has been told to send it back to them with a note telling Quark to stick it where the sun doesn’t shine. The last two experiences were not pleasant with them.
If that happens I’ll switch to the Garmin vectors and a crankset that has nothing even remotely to do with Quark. So far I’m not faced with following through with that threat.
KonaCoffee,
Would you mind emailing us at thinkfast@quarq.com? Something is not adding up here if you have had to send your unit in so many times and I would like to look further in to this.
Cheers,
Rob Bee
Quarq Tech Service
Anyone who owns a Trek SC 7 with a Quarq? Which model did you go with? Which models do I consider? My SC 7 currently has Shimano 105 crank with Ultrgra front/rear gears.
Hi Linde,
The Trek has a BB90 bottom bracket which will take a GXP spindle. All models are available with either a GXP or BB30 spindle so really you could go with any model. If you are using Shimano 11 speed drivetrain, you may want to look at the ELSA RS. Otherwise all models will fit a standard 5 bolt pattern ring in either 10 or 11 speed.
Cheers,
Rob Bee
Quarq Tech Service
Hi Linde,
Cheers,
Rob Bee
Quarq Tech Service
Rob, does it matter that I have 1st generation SC? It’s a 2011 model
I bought a used S975 on BB30 spindle, and it suffered heinously with zero offset drift. It was under 2 yrs old and they sent me a Riken under warranty (replacement spider on the original cranks and chainrings) which is awesome, much more stable. I still get around 10 points drift (on zero offset) from start to end of a turbo workout but it’s no biggie.
That’s still only just less than 3W @90 rpm (each offset point is just 1/32 N-m). Do you have the latest firmware loaded? They added a clever algorithm to counteract the drift from just the electronics “warming up”. If you haven’t already, download the latest firmware. Otherwise, do another offset zero ~5-10 minutes after starting your turbo session and you should be able to cut down the drift even further.
I found the magnet placement challenging with the new Riken spider on my Cervelo P3, but I suspect this is particular to my setup which is a BB30 chainset with Rotor adaptors in my BSA frame.
Again, get the latest firmware. No magnet needed any longer ![]()
I haven’t been paying very close attention…any limitation to the max cadence that can be accurately measured w/o a magnet? What about maximal power…has anybody compared the highest values achieved/achievable w/ and w/o a magnet?
Cheers Tom. I do a manual calibration in TR after warmup and then again usually after the first proper interval. Most of the zero offset drift has happened by that point, I might get another couple of points by the end. Before doing the calibration I have typically picked up on a small cadence increase necessary to hold the same power, but it is hard to guage this accurately because at the same time my KK trainer seems (to me) to reduce it’s resistance ever so slightly through the workout. That is to say that after calibrating the zero offset again during a workout, I still note a small - maybe 1 or 2 bpm - increase in cadence is necessary for to hold the same power in the same gear.
Yup, I definitely do need the firmware upgrade and was excited when I read a couple of weeks ago about the accelorometer. I’m hoping that will cure my occasional dropouts that I get, because of my slighly dodgy magnet placement. I hadn’t done that yet because I was on iphone 5 and didn’t want to buy the 25 pin adaptor and the ANT+ key, but I’ve got to thank you because your note made me go and re-check the Quarq webpage and I can see now that there is a Windows version!! So I am going to do it now!!
Thanks,
Rich.
Here’s what Jim had to say back in July on wattage: https://groups.google.com/...yW3M-TE/8sQBE3Ycf3EJ
I’ll chime here:
Change log for production firmware is on the web site. http://www.quarq.com/...ort/firmware-updates
Qalvin for PC: https://www.quarq.com/qalvin/
Qalvin for Mac: All done. Almost through the Mac App Store acceptance process. Stay tuned for release.
Accelerometer cadence is now in final testing. There are some not-so-secret beta testers in the field. We are coming down the home stretch to public release, so here are a few details.
We have been working very hard on accelerometer cadence for quite a while. The accuracy and performance of the magnets and reed switches is very high, setting a high standard for expected performance.
All Quarq power meters with an LED and CR2032 are compatible with accelerometer cadence. When ready, we will release a new firmware for these devices.
Accelerometer cadence is automatically enabled when the magnet is dislodged or removed. No user intervention is needed.
Accelerometer cadence offers convenience and was developed for bikes that have limited options for magnet placement. Performance is excellent up to 160rpm and in all but the most extreme vibration environments. A magnet is the preferred method for cadence measurement. It ensures that cadence is the most accurate no matter what the conditions.
In terms of accuracy, single pedal stroke cadence accuracy decreases by a maximum of ~2%, but cumulative accuracy is unaffected. There is little or no impact on cumulative power values such as kilojoules, average power and normalized power.
Benchmark tests show the accuracy of Quarq’s accelerometer cadence matches or surpasses other products that use accelerometers for cadence.
Jim
So…looks like it’s good up to 160 rpm, but may go higher? Would have to ask Jim Meyer on that.
Sounds like maximal power could be off by at most 2% as compared to a magnet trigger due to the single pedal stroke cadence accuracy.
edit: BTW, if anyone is interested in what was changed for the electronics drift issue, here’s what Mark Rages had to say about that: https://groups.google.com/d/msg/wattage/7BEFyW3M-TE/vx-Qv_9Qyo4J
We discovered that the measurement electronics (not the strain gages or mechanical part) were contributing their own drift after they powered on, requiring a few minutes to settle out. I adapted an old analog electronics technique to continually measure this drift and subtract it out of the measurement.
It’s a closed-loop correction. Nothing is being painted over or fudged. The remaining drift is from the strain gages and mechanical circuit.
Because the first few minutes after power-on coincide with taking your bike out of the climate-controlled garage, the initial drift was sometimes wrongly attributed to temperature changes.
Regards,
Mark
mra...@sram.com
Hello Kauphy,
You are correct that the RIVAL22 cranks have a removable spider, but we do not sell a spider only option for that crank. The RIKEN R Chassis (Power Meter and Cranks) would be the best option in this situation. The price for the GXP crank is $1200.00. This is quite close to the Spider only option that P2M is selling, plus you get a higher quality, lighter crank out of the deal.
Regardless the direction you go, just wanted to clarify that you wouldn’t be able to send in just the crank and have a spider installed.
Cheers,
Alex
