Does anyone have any recommendations on sodium and/or electrolyte pills? Sadly, I am a perspiration machine and think one or both is a good idea for me. I have sporadically taken electrolyte pills and they seem to help but at the last 1/2 IM I was getting chills and was definitely out of whack. With heavy training coming up in the next few weeks and IM in a couple more after that, your recommendations are very appreciated. Thanks!
I like to see the replies in this thread also, I tried e-caps by hammer a few years ago during a 1/2 IM, and might have overdid it, and also experienced chills in hot weather.
Hammer e-caps work. But, follow the recommended dosage - you need to take more than just a few. If you try to scrimp, they don’t really work. There are others that aren’t as expensive and I’ll bet they work, too. Along with bananas, consider cantelope the during the summer and prior to exercise.
I’ve been really happy with thermolytes.
I second the Thermolytes. Just ordered another batch this am.
I have used the thermolytes with success but I recently switched to using the e-caps because they come in tablet form instead of just salt pill form. If the thermo’s ever got wet they start to dissolve or fall apart. I had an issue with this a few too many times.
I use the salt stick caps now, and love them. Used to use the thermotabs, but they were a pill, and the saltsticks are in a capsule. I think that way they get a little further along before exploding into the digestive system… I also like that they have a little magnesium and potassium in them. Not a ton, but from what I have read, those two help you absorbe more of the salt. As I look at the lable now, it has a fair amount of vitamin D too, not sure why that is, I will have to ask next time I run into the owner…
I also use the Salt Stick variety. Work well for me. During my summer training here in AZ, I typically take 3 to 4 tabs per hour riding and 1 tab per mile running and have never had an issue.
salt stick tabs have been huge for me. also, check out the bar end dispenser - really a great design.
Just a few questions about salt intake…
What is the “normal” prescribed amount needed per hour?
Are salt pills able to be taken on the bike and run, or is it really used only on the bike?
Also, on the bike for a half/iron…what is given at the bottle handoffs? Is it just water? How do racers get the electrolytes from water? Is it simply enough to have water+salt tablets OR do you need Gatorade/electrolyte drink + salt tablet.
Are salt pills able to be taken on the bike and run, or is it really used only on the bike? \
It is highly individual as to the doses. Some people need handfulls, others do not need anything. I figured out my dosing according to my bodies cramping. If I feel even a twinge, I would take a pill or two. So over the years I have found that about 4 an hour work well for me, and I know lots of pros that take 30 to 50 during an Ironman…
It is easier on the bike to take them, but you can take them on the run too…It is just that they will be more effective the earlier you take them. If you take pills in the last 30 minutes of a race, they will help you recover, but not likley to affect any performance during the rest of the race…
Remember that whatever you do, make sure it’s based on YOUR body’s needs.
THe 600mg is a pretty good benchmark. I run ultras more than anything, and I use Salt-Stick capsules frequently. Probably just 2/hr, but that’s 14-18 tabs over the course of the 6-9 hour race (depending on dist.) PLUS whatever is in the fluids.
IMHO, people take too many electrolytes and not enough “balanced” electrolytes (balanced out with water)…
For me, I increase my sodium intake the day prior to the event (half or full IM events). I add salt to what i am having for dinner. Temp on race day should dictate your consumption of electrolytes. Too much can leave you bloated on the course and have negative impacts.
I lace my fuel bottle(s) with a minimum amount of electrolytes, then go ‘on-demand’ with tabs based on heat and perspiration *small ziplock in my jersey pocket). Watch for salt stains on your tri shorts, that is a good barometer. Leg cramping is also indicative.
I tend to go more conservative on the salt intake. Rehearse during training to dial it on all in.
I’m an advocate of Hammer products. It’s important to note the salt concentrations are different by product (i.e. Thermolytes are stronger than Endurolytes).
Just throwing in a vote for the S!Caps < http://www.succeedscaps.com/main_scaps.html > here. I like the fact that I needn’t take as many. In CO, HI or TX they have served me well and I’ve been known to take up to 6-8 an hour.
+1 for Succeed! caps. I sweat like Mike Tyson at a spelling bee, and they are the only thing that keeps me from cramping up.
Salt Stick all the way. Endurolytes if you like carrying a zillion of them to keep up with sodium, Succeed if you like puking because they’re so bloody strong (high sodium), and Salt Stick if you want just the right amount with buffers that won’t upset your tummy. Plus, Jonathan Toker PhD (founder) was a pro triathlete & knows his nutrition so he developed a great product. To top it off, the Salt Stick is the single best method of carrying salt pills on the bike hands down. You can use Infinit and load the salt into that formula, but you may want to go a little lighter on your formula if you customize it, and supplement according to salt loss on race day with Salt Stick.
I use infinit in concentrated bottles. Has anyone taken the salt stick tabs and “emptied” them into the bottle to boost the salt level of the drink?
Neal
S!Caps. One ever 45 - 60 minutes got me through a long hot day yesterday. The creater is an ultrarunner and does a lot of research into what he makes. Really accessable guy, lots of good info on his site. I used to take Endurolytes and would need to do 4/hour on a day like yesterday.
My last HIM I made a 3x concentrate of infinit supplemented with 9 saltstick caps. The tase of the drink is very salty- first sip I thought it was gross, but that quickly changed and I quite liked the salt cocktail (diluted with course water).
One thing to watch is the osmolality- you are putting this well over the reccomended level with the supplemetary salt. My stomach was a bit queasy for the first few km of the run, but this subsided (I continued to take salt caps with on-course gatorade and felt fine).
