Saddle position moved if aero bars dropped?
I am trying to get a bit lower in my position. I have removed 30mm of spacers from my aerobats - do i need to move the saddle forward as well?
More drop means you elongated your reach. Here’s the problem though… when you’re fitted to a bike, you start with the pelvic position in relationship to the bottom bracket and then fit everything around that. By dropping the front, you have changed the reach and may need a shorter stem to compensate for that. You shouldn’t move your seat…
Not necessarily. Post some photos and we’ll let you know. :wink:
