I have a still image taken from a video with me spinning at ~95rpm on the rollers that I am going to use to measure some angles. My seat is obviously a little low (no, really, it is) and my heel is still raised at bottom-dead-center (BDC). So, this must be just how I pedal and not due to “reaching” at the bottom of the pedal stroke. Now, to the questions…
When I measure my knee angle, should I measure it in this position (ie. with my heel raised) or should I take a static pic with my heel more level?
Assuming “as is” is the answer to #1, should I still shoot for 150* or should I shoot for something a little on the lower end (maybe 148-ish) of the 145-153 range to account for the fact that this angle would be larger if my heel were level?
The video was taken in a very light gear (small chainring, mid-cassette). Would this have any affect on my heel angle at the bottom (ie. do you think my heel would be more level if I were pushing a bigger gear)?
Is there a general guideline for how seat height affects the knee angle? For example, if you want to increase your knee angle 5* you’ll need to move your saddle Xcm higher.
Dr. C explained this pretty well with the 96% or trocanter height. Look at that thread. This will give you the correct knee angle. I was a little out from this but have now made the change on both bikes. A bit lower than used to sitting, but overall feels good.
Note that there is an optimal range, which is 96-100%.
I think there’s some confusion. Here are the facts…
I shot a video with me spinning on the rollers.
I can pull frames off of this video to take the angle measurements.
My seat is obviously a little low, yet I am riding heel up.
I would like to use the 145* - 153* knee angle range as discussed in the FIST articles to set my seat at the proper height (according to FIST).
So, my questions are…
Do I measure the knee angle with my heel up, as I ride -OR- do I take a static photo with my heel more level, even though that’s not how I ride, and use that to measure the knee angle?
FWIW, I did both method last night, and the difference in knee angle between heel up while spinning and heel level static is ~6*.
I believe the correct answer is to use the frame taken from the video. Assuming so…
Should I shoot for something on the lower end of the 145* - 153* range because the angle would actually be greater if my heel were level with the idea that’s it’s probably better to be a little low than a little high (as discussed in the FIST article)?
I will post a couple of example pictures in a minute to show what I mean.
He rides with a level heel at the bottom. (If my reference points are correct, his knee angle is ~139* in this photo.)
As opposed to Pro #2…
She rides with her heel raised quite a bit. (Yes, I know that she is a little past BDC. It’s the closest pic I had to illustrate my point. So, humor me.) (Her knee angle is ~134* in this photo.)
I ride more like Pro #2, in that my heel is definitely up at BDC. This results in a measure knee angle of ~6* less as compared to a static pic with my heel more level (as shown in the Faris pic).
Thanks, stand corrected. Does this mean I can put the seat back up ;^)
I would say that depends on how you arrived at that saddle height in the first place, and how long you’ve been riding in that position.
To be more specific: I wouldn’t necessarily advocate changing somebody’s long-used position solely because it was outside the 96-100% range. OTOH, if I were trying to assist a new rider, I’d set them up in that range for starters (favoring the lower end if they were more of a TTer and the higher end if they were more focussed on sprinting, and/or had a history of knee problems).
You don’t determine saddle height from taking a measurement from a photo. A fitter will take the measurement as a guide, but the actual seat height will come from watching the rider pedal over a period of time…and using a SpinScan would certainly help. Head over to Maplewood or Big Shark (I recommend Big Shark, btw). Otherwise…toss up your vid on YouTube!
The photos are misleading b/c FAS is falling off his seat and photos are distorted versions of what is happening.
Isn’t that PNF in the lower pic?
And didn’t she use those weird crank extenders?
Yes it’s Paula and yes she used those funky articulated cranks in that shot on her 24" Felt.
Just an FYI: his greater trochanter is a bit forward of where you’ve drawn your line (which means his knee angle is a bit larger).
Thanks. It does appear to be a little further back than I placed it on PNF. Would you say that I placed it correctly on her?
It’s certainly close, but I’d still draw the line a hair more vertical than you have (of course, we’re both just guessing).
