there are some big bruises on my legs (yes, from the roller crash), and i’ve been running even though they hurt. but today one in particular hurts badly…it’s on the interior knee.
this makes me wonder, is it harmless to run with bruises, or is it bad? or does it really make no difference?
I can relate. I ran after getting hit by a car on my bike. I had a very deep bruise on my hip. Deep enough that there is still a lump there >1 month after the crash. It hurt, but I didn’t see any other ill effects. A bruise right on a joint, however, could be more trouble. I had a good solid layer of fat fo buffer mine! Be careful with it!
Bruises are fine to run with. Obviously, if there is something else going on with your knee, then no, but you have had on/off knee issues for a while (right?) so you should be able to differentiate I hope. You seemed to run fine for almost 10 miles in the mud on Sat
yes, and i ran yesterday too. there is a bruise, but i’ve touched it (like a dummy) as if I’m in denial. “is there really a bruise, or am i imagining things?” that sort of thing. now my imagination has run away and i don’t know what to think. “is it the bruise that hurts, or am i injured?”
so, maybe i should just run and quit thinking about it. (and stop touching it might help too. lol)
I will assume the pain on the inside of the knee was NOT painful ever since you wiped out…If it’s been painful ever since, AND doesn’t go away, then Im concerned that you may have done more than just a bruise…i.e. collateral ligament strain or cartilage tear…otherwise running with bruising is not dangerous just do it as ‘tolerated’…
I’m expecting docfuel to post anytime soon…
Ha!Ha!Ha!
anyway, miss Kitty, if it is unexpectedly worse, it could be something you did in the mud run thing that you did, OR you’ve altered your stride and are injuring your medial knee structure, expecially if you are letting your hips sag (weak hip abductors) or slow cadence, or both. If it’s not better with a little rest, you might want to have your knee checked and/or possibly have someone (Francois) check your gait.
Oops! see the above. I should have addressed it to you.
After my little crash the other day, I’m a little concerned that I’ll alter my gait when I start running again, and end up with a problem, since my hip abductors are a little bruised. If the hip sags, that will strain the knee.
thanks everyone. my husband insisted that i sit and ice it. so i did that and we’ll see where that lands me tomorrow. (no run=pouty kitty!)
my knee was acting up after a race i did on Jan 1, hence the concern (but the inflamation was in a different spot than what i’ve got now). also there is a big blob bruise on my lower calf and that hurts pretty good too. so i’m really hoping it’s just bruising and my touching it a few times too many.
i’m really tempted to give in and buy a trainer after all of this.
