My current pair of Nike’s are causing rashes all over the place and need to go. They are also probably 8 years old. I am open to any and all brands. I did purchase my first pair of Lululemon running shorts early this year and as much as I think the price was ridiculous I will say they are built very well. Would be interested if any one has any experience with their running tights. Especially since I could then match my wife when she wears her lulu yoga pants.
How about Running Funky?
One word: “Juicy Couture”
Already have a Juicy jump suit for formal events, like funerals.
sporthill
I use performancebike.com bike cycling tights without a pad.
Really depends on the temp. I like the thermal run tights from 2xu for cooler runs 45 and cooler, and the regular 2xu compression tights for 45 and warmer. http://www.2xu.com/thermal-tights-mr2480b.html
I am a 2xu athlete but wore Nike and Under Armour in the past. All are nice.
My husband likes the Frank Shorter Running gear: http://www.nationalrunningcenter.com/category/91. I’ve worn a warm pair of men’s Sugoi tights for the 8 years as well and really liked them - the elastic at the ankles are finally starting get loose (and that’s after being used as my primary running tights every fall/winter).
CW-X Stabilyx tight. Been running in them for five years. Just managed to kill my first pair here. Living in Maine and have never found a reason to step up to the insulated version.
Gore makes a air of windstopper cycling tights that have a removable bib tops. Remove the bib tops for running and you are a two in one piece of clothing that can be used for cycling and running. Like one previously stated, what type of tights depends upon the weather.
I have a pair of Lululemon running tights, about 3 years old and I wear them at least twice a week in the Winters and they still look new.
CW-X
been using them for years. top notch quality. Highly recommended
Cwx been using for a few years, just ordered some craft wind proof tights, reviews sounded descent
I use UA and nike dryfit. I also have a pair of the mizuno ones that turn sweat into heat(or something) but they’re a bit big for me so don’t wear them as much.
I wear Sugoi in the great white north, and it keeps me warm on even the coldest days…
2x U are great.
This past winter I picked up a pair of Pearl Izumi bib tights, and although I bought them for cycling, I now run in them, as they are so incredibly comfortable. They are the ones with no pad, I think their select model, and they have become my go-to pair of tights. By the way, they run fairly long, which is awesome for me, as I can not usually find tights to fit. They also have the zipper bottoms on the legs so you can snug them tight after putting on over shoes. You may just love them as I do.
I’ve tried a number of tights over the last few years ranging from Nike, Under Armour, 2XU, MEC (a Canadian company), and Adidas. They all were pretty comparable but if I had to choose just one brand I’d go for the 2XU ones. I found they had great fit, durability and the amount of reflective material helps keep you visible during the dark months of the year.
Have both you mentioned…I really like the Craft, but they can be warm
Thank you all for the suggestions, definitely a few brands thrown out there I had never heard of before which I need to check out.
