So am relatively new to all this over exercising ;). I’m just under way in training for my first marathon. After 4 miles, I wanna blow my brains out running on a treadmill, which I’ve been doing b/c it’s so dark in the a.m. That, however, needs to stop and I need to get outside…
My question is what do folks use for lighting on the run? I have a Petzl headlamp that I use for hiking/camping but am wondering if a headlamp is awkward for running?
I’m concerned about not breaking my neck so want to see, rather than be seen – I mean I have flasher lights, and other reflective gear to be seen, it’s illuminating the path I’m wondering about.
I go with any of the various LED lightweight headlamps (usually Petzl). Also wear lots of bright reflective clothing so there is less chance of getting run over.
try doing a forum search as this topic has been discussed recently.
yeah, i seem to recall that, i was just being a tad lazy
if you have any hints on using the ‘search’ feature, that would be helpful b/c i must be slightly retarded as I never manage to get the right combination of words to do a proper search and spend more time digging than I should. I’ve come to see there are many who are more qualified than I here and are quick to reply with sage advice …
I bought a $20 one at REI that works fine. The light isn’t bright like a car light but it does the trick. It’s pretty cool being out in the dark with a headlight on your head. Makes the miles seem to go by faster. I also wear a reflective Nathan vest with visibility from 500 feet…
The Petzl Tika is good if you don’t mind wearing something on your head that means “small penis” in Yiddish…
Fuel Belt makes a similar device that has one or two more LEDs and is much brighter. I’ve seen others, but the Fuel Belt light is my favorite. So lightweight you won’t even know you’re wearing it. Batteries last about 25-30 hours.
Last week I took the light off the strap as an experiment for a future modification. You can wiggle the black stopper that is on the end of the strap, and remove the light, and then put it back on.
Why?
How about to wash the strap? Don’t you sweat?
when i ordered it from amazon, one minute it was the price listed in the link, and then i looked at other stuff and came back to the headlight and it was only 22 dollars. !!! but either way, it’s a great device, and there is no weird headstrap thing, the strap/cord thingy is retractable and works great. the light is very bright, and has 3 levels of brightness. i do wear a hat with it though to prevent my hair from becoming a bird’s nest.
I saw a Nike-Light on their website today…you strap it around your arm and it radiates light in all directions…looked kind of cool…I might get one. While we’re on the topic, does anyone else experience neck pain when wearing a head lamp? I’ve been running in the dark A LOT this winter and my neck just kills after 45 mins or so…it only takes a minute to stretch…but it is very uncomfortable running…not sure if it’s my light or if my head is too far forward…
I do a lot of night trail running, like twice a week with a small group. For me the key is a basic headlamp that is comfortable (we all have different ones and no-one spent over 30 bucks) and complimenting the head lamp with a small hand held flashlight. The combination is plenty bright and it is nice to be able to point the handheld at things you hear in the darkness and occasionally at cars coming towards you.
So, I suggest two cheap lights. Seems to be more effective than a single head lamp (even a really good one).
do you experience the pain when you don’t run with the headlamp?
if so, check out the product i posted–it’s so lightweight i forget that i have it on my head. make the change, it’s worth it.
