Running Heart Rate
For some reason I can’t keep my heart rate in zone 2 for base building unless I go rediculously slow (11 min/mile +). I have no problem doing so for cycling. I used the treadmill test in Friel book for determining my zones and Max Heart rate which is 194 for me (I am 27) . According to my recent 5K time and based on Jack Daniel I should be training in 9 to 10 min/mile for my easy pace. Which way should I go ? One more thing is that I am not perceiving a really hard effort though. The same heart rate on the bike would have killed me, but I can even talk pretty well although I supposedly pass my aerobic threshold.
This is my opinion only.
Use Daniels pace
jaretj
I’m the same way. Your zones are probably wrong. Try to set them based on a field test- 10k HR is supposed to be a good measure of lactate threshold. (someone correct me if I’m wrong) Maybe try setting your zones based on that?
(for example, the top of my zone 2 based on HR max is 156. I can run a comfortable half marathon at 185)
Jodi
I do what Jodi said, but do it based off of a 3 mile all out sustainable run. After doing this, your avg. HR should indicate your LT. I have been working on my base and at the start I was running 11-12 minute miles. It gets better!! There was a thread or an article posted awhile ago that discussed an individual and his base training. It was pretty interesting and Eye openning for me. Of course I cant find it now.
I find that I can run for a long time in zone 3 and 4, but I believe that if I build a stronger base, which I never did in the past that I will be able to run faster at a lower HR and thus go further at this rate. Now I just need to fix my back so I can start training again.
I would think that you would run a 5k fairly anaerobic. I know that my HR ave would be >195 for a 5k. I don’t think I would be comfortable using that as my LT…
Jodi
My comfortable running and biking HRs are easily 20 beats off.
I feel like I am dying when I cycle at my easy run heart rate.
I always assumed that my bike muscles were my limiter not my heart vs. running where my run muscles can keep up with my heart.
Jodi
Jodi
Before the physiology police come get you - even a 5K is “aerobic” as an anaerobic race wouldn’t be too long. But yes, you are well above your LT for the entire race
Use pace, then RPE, then HR. Cycling and Running HR’s are not interchangable. They may or may not be the same but they should be determined during seperate tests specific to each sport.
What I would like to know is that if running like a snail but keeping the heart rate low (under 154 for me) has any benefit for me. I mean if I force myself to do it for 3 months, and I get out of it without losing my sanity, will I become significantly faster below that heart rate ? How will it affect my running form ? I feel I lose my form when I go too slow.
I also learned that it really matters how I start the run, if I really pay attention at the begining and start super slowly, I usually have an easier time to get a faster pace in that zone.
Personally, I think Daniel’s paces are a little quick for most novice to intermediate runners.
e.g. for a 20:00 5K runner, Daniels recommends 8:40/mi (75% of race pace)
However,
for a 15:00 5K runner, Daniels recommends 6:30/mi (70% of race pace)
Doesn’t seem fair to me. :slight_smile:
As Brian said, I would recommend looking at all variables, with the caveat that most novices kind of suck when it comes to reading RPE. Regardless of your ability to talk, if you are hearing a rhythmic breathing then you are training too hard IMHO.
Personally, for base training, I look at RPE, HR, Pace in that order. For build/specific prep training, I prioritize according to DD’s recommendations.
Hope this helps.
Cheers,
Alan Couzens, MS (Sports Science), CSCS, PES
Certified Triathlon Coach
Running like a snail is meant to ensure you: 1. are fresh to run much faster about 2 days a week and/or 2. ensure you can run a lot and get in lots of mileage and/or 3. ensure you are able to train hard on the bike … You need to run slow enough on those easy days that you are able to do your other workouts well. If you feel you can run faster on your easy days and you are really sure it won’t compromise other workouts, I say run faster. Just my opinion.
Barry drove me insane making do this for two months… however it does work.
my zone two starts at 172, in september i was running 9:20 mile pace at this and barry didn’t want me to go much lower.
Now with my HR at 172 i am around 7:30 mile pace. It works but it takes time.
As has been said many times on this forum don’t start icing your cake before you have a cake. # months is nothing in endurance sports, i’ve had a longer base period over the winter. Just stick with it dont change just because it doesn’t feel like it works.
Instead of going slow losing your form, increase your cadence.
However,
Yes, but the 15:00 5K runner will be running at 75% of the pace that he could race for 20 minutes. Get it?
It took me a while to wrap my head around this, but it finaly made sense. It’s the time spent at a certain HR that counts, not the distance that he runs.
I agree with Barry - Daniel’s formula is about spot on. It will seem a little fast/hard at first, but works great for most runners (even intermediate one’s, whatever that may mean). Complete newby runners? Perhaps not since their threshold for injury is so high (always a concern of mine). I’ve only recently incorporated his pace charts into my training (over the last 2 years) and the results have been nice indeed.
Yes and no. A lot of tri books recommend this and it used to drive me nuts because running books were rocommending 10 to 13 mile race pace. Then it hit me. Triathletes typicaly run slower than runners. ie…I did a 10K tempo run last night and can bet you anything I didn’t do it at 10K race pace! ; ^ )
The HR you should base it off of is your one hour race pace. If it takes you an hour to race a 10K then yes, use your 10K HR. If it takes you an hour to run 10 miles, then you’d use your 10 mile HR.
Anyway, Desert Dude is right. If there’s a discrepency between HR and pace, you should use pace.
I’ll post the link again. Use it!!!
http://www.mcmillanrunning.com/rununiv/mcmillanrunningcalculator.htm
It’ll tell you what paces to do your workouts in based on recent race performances.
I agree, zones may be off. I think a 10K could be a good LT test, but I prefer a slightly different protocol. A deep warmup, followed by 30 minutes of hardest running you can sustain for that 30 minutes, and then take your average HR for only the last 20 minutes of that run. Your HR monitor would need to be able to give you an average HR in order to do this.
Hey Barry,
I just did the math.
Still seems a little off, e.g. for our hypothetical 15:00 5K runner, he runs a 10K in 31:10 (from the tables).
This means his base pace of 6:30 is 77% of his 10K (31:00) race pace.
So, if he loses 7% over 15 minutes, tacking on 5% for the first 5 of those 15 seems a little excessive.
I do get your point, though.
However, if it were me, I would be more inclined to suggest that since endurance is typically less well developed in novices than elites, if anything the base pace should be a lesser % of equivalent duration race pace.
That said, it’s not true of all athletes and that’s why monitoring pace in addition to HR is, IMHO, all runners best bet.
Cheers,
Alan
What are you training for? I wouldn’t just use a 5k to determine your long run pace. I would want to take a look at your 10k and 1/2 marathon times as well. I look at 5k ,10k 1/2 marathon times ,MAF test ,and then I use this chart to help figure out the appropriate pace /HR http://www.mcmillanrunning.com/Running%20University/Article%201/mcmillanrunningcalculator.htm
Here is what I have done in the past year just to give you an example
10K time 44:01 using the Mcmillan calculator this puts me between 8:23-9:53 for my long /recovery runs
1/2 marathon 1:39:26 … Mcmillan put this at 8:31-10:04s for my long/recovery runs
Seattle Marathon 3:36:36… Mcmillan put this at 8:46-10:16 This was my most recent race. I believe had the weather been better I would have been under 3:30 This is what I predicted based on my MAF test a month prior to the race, my MAF is 10:00 min miles.
I don’t think you should look at 1 race to determine this. I think a 10k or half marathon would be a better predictor especially if you are training for longer distance races. I think you need take into consideration all the above… do a MAF test too. How long have you been running? For someone new I would definitely recommend the lower number when starting out . If you have been running many years then you will probably find you are able to run at the higher end.
