Has anyone used the lights that clip onto your visor of your running cap?
Do they work as well as a headlamp?
What are they called?
How is the battery life?
Do they stay attached?
Thanks,
FP
Thanks,
FP
I have one and only used it once but I think it is awsome the LED is muh less clunnky than a head lamp. I cannot remember the name of it and it is not in front of me ut I got it from MEC.ca which I think is like rei in the states. They’re pretty inexpensive too.
I use the Petzel Zipka Plus - works a lot better (brighter). I just talked Kittycat into getting one too so she now also looks like the ultimate running geek ![]()
I’ve got one and really like it. Maybe not the best in terms of seeing obstacles (it helps but still be careful) but you will definitely be seen by others. It stays clipped on very securely. I have only had mine for a little while so I can’t help you with battery life. Walmart for $10.00.
