Lower rpms are more “efficient” as far as power produced per calorie burned. This is pretty obvious since human muscle is SO inefficient…so much energy is wasted on each contraction, it makes sense that decreasing the number of wasteful contractions each minute is more “efficient”.
But, the trick is to find where “efficiency” and available muscle glycogen consumption rates best meet the criteria of the individual’s physiology and the race distance/speed at hand. If you can store glycogen and spare your glycogen by having a lower burn rate/kg better than I, it seems to me that you could race at a lower rpm than I. Or, if your muscles were better vascularized, thereby sparing glycogen by being able to utilize blood glucose better than I, you could race at a lower rpm. Or, if you are lighter, going uphill you could race at lower rpms than I, because I have to burn more glycogen/kg to haul my heavy rear up that hill. If I “muscle up” and crank over that hill to keep up with you, my glycogen burn rate just sent me into a burn rate that I cannot continue for long…that’s OK if the finish is at the top of the hill…but, if we have 50 miles to go, I’d better conserve glycogen so I can have something left later.
Then, we have to work out muscle perfusion availablility due to cardiac output, size of the muscle perfused, and tension in the muscle to determine the “best” rpm for an individual. Shorter TT’ers tend to have lower rpms, because they can afford to burn their glycogen…the race isn’t going to be long, so they aren’t worried about whether it is calorically efficient or not. On the other hand, RAAM riders tend to have lower rpms, too…it’s more calorically efficient, but they apply much lower force per pedal revolution than the short TT’er, so they aren’t depleting available glycogen very fast and/or they aren’t exceeding the rate of blood glucose delivery.
Somewhere in the middle is what most of the rest of us are doing, and it makes sense that the rpms would be somewhat higher for an individual in the middle distances. One person’s range might be circa 70 in the middle distances, mine might be circa 80, someone else’s in the 90’s. If any of us were to do a shorter race, or a much longer race, our “ideal rpms” might change to a lower rpm.
Does this seem to make sense? If it does, it would behoove people to stop chasing real high rpms (because Lance Armstrong turned 120 on a mountainclimb), or to stop avoiding lower rpms (because low rpms are what beginners do), and to experiment to find what’s best at different distances/speeds.
Surely one rpm isn’t best under all circumstances for any one individual…whaddayathink?
