7/14/09
650c zip 404s with disc cover
bontrager aero TT tires
Quintana Roo/Merlin Aerial frame with drop bars. Tri geometry, round, small diameter tubes
kat’s average speed: 23.6MPH
average speed of 10 other consistent riders: 27.04mph
7/28/09
same TT, same time of day, same wheels/tires
Cervelo P3 aluminum frame with vision base bar. All contact points indentical, so position is the same.
kat’s average speed: 24.3mph
average speed of the same set of riders: 26.4mph
So, on a day that was a bit slower in terms of wind, she got quite a bit faster switching from a small round tube frame with dropbars, to an aero tube frame with aero basebar.
Am I correct in my understanding that the first trial was ridden in the drops? Because the increase in speed could then be attributed to the use of aerobars only as there isn’t a single variable. Though this would suggest that aero increases speed/decreases split time, the initial use of drop bars would disallow a conclusion to be made about the effect of the tube shapes. I.E. She rode faster because of the aerobars despite the aero tubes.
Thanks for breaking some new ground for us, Copernicus!
(How do I make that pink?)
Our conversation of this topic last week yielded somewhere in the neighborhood of a 7.8% improvement.
Based on speed, this is a ~4.75% improvement.
Ergo, faster, but not as much as we might expect?
However… the 7.8 figure was over a large round tube bike (Madone, Tarmac) and we all know that while round tubes suck, small round tubes suck less than large round tubes.
So I’m comfortable with this confirming the numbers. Thanks for sharing!
the first trial was ridden on the same size and brand TT clip ones (visiontech ski bends) with the exact same contact points as on the P3 aluminum.
I have graphed my average speed vs hers vs the top 70 in the event for each date.
As you can see the wind was making the 2nd trial quite a bit slower for the top 70.
That’s a pretty fast group, average speed 27 for the entire group. I sometimes do a TT series in Concord MA and, while I’m not sure about the average speed for the field, the median is usually about 24-24.5, but we’re talking a larger group, 30-70 people per night. Fastest times are usually about 28-29 mph, with course record right at 30. Karen Smyers holds the women’s course record at 25.7 mph. Mostly licensed racers but more triathletes lately. Course is gently rolling, about 250’ of climbing in 9.8 miles.
Edit, saw your latest post and realize you’re only talking about a selected group of 10 riders, that makes more sense.
yeah I’ve made the science better and now include the top 70 riders in the graph above =)
power is the uncontrolled variable here. we both may have been more fit.
The only thing missing is some measurement of power applied so that both the demand and supply sides of the equation can be evaluated
Yup…and even though this is highly “suspect” to do…eyeballing both of your “upward trends” relative to the top 70, it appears that it would be a reasonable assumption.
edit: Then again, maybe the conditions have just gotten warmer over that span of time
FWIW, I would concur that the conditions were not favorable last night. Chris & I both set near PW (personal worst) for the year last night and Chris’s power was right in the range of her previous runs. Mine was a little lower thanks, I think to the 40k TT I did on Saturday.
The amazing part is that Patrick still set a PR averaging 29.9 mph. 4 secs off 30mph.
Certainly a strong improvement for Kat and in the end who cares if it was the frame or the training or both. She went faster. It may have been placebo, but in the end, faster is still faster.
<< Our conversation of this topic last week yielded somewhere in the neighborhood of a 7.8% improvement.
I find that number extremely hard to swallow. So if I understand this correctly you are saying going from a round tube frame to an aero frame you would expect to see a 7.8% drop in time?
I’ll actually be able to put this to the test in two weeks at our monthly club time trial. I’ve been doing them for years and have always done them on a round tubed Merlin Ariel. For this next time trial I’ll be on my new TTX. Typically I am anywhere from 29:10 - 29:30 on average for this time trial, so a 7.8% drop would equate to cutting a bit more then 2 minutes off. I would love to be able to do that but I am skeptical.
Just make sure “all other things are equal” (or accounted for) in your comparison…and don’t forget that aero drag is only one part of the total resistance.
interesting mike, almost exactly duplicating our experiment
be sure that all contact points are exact. seat to pedals, drop, seat to bars, and so on.
and use the same wheels/tires!
i dont think you will see a 7.8% drop, since the merlin has smaller tubes than your normal aluminum frame
there will be some slight differences, but not many.
Same aero bar set up
same tires, although old set up was 650’s new set up is 700’s
different wheels, Ariel had Renn 575 disk and HED3 (650’s), Trek will have a Stinger 60/90 combo with PT SL+
