Rollers Force Curve? Interval workouts?
Anyone have a source of this information (speed vs. power)? I know it is dependent on roller diameter.
Does anyone make a set that would allow you to do a decent interval workout?
I started out on rollers… rode them for 2-3 years before getting a trainer. My experience says rollers are good for HR intervals and working on leg speed/spinning. They are not however, the best thing to use to develop power. Like you already mentioned, there are a number of variables (drum size, drum material, resistance units, etc.) when it comes to roller resistance. I used HR and RPMs as the main gauges of my efforts. My leg speed and spinning was amazing when I just used just rollers (could hold 150 RPMs for 30 sec. and maxed out at 200+), but had very little POWER.
JB
many models have resistance units that you can add onto them that would allow you to do more force workouts. Minoura has a mag resistance type unit and Krietly has the killer headwind. I’m sure the other manufacturers have something similar. Kritler also makes tiny diameter drums (2.25" or something like that) that probably would make for some high resistance as well.
I have a set of American Classic Rollers - the ones with six small diameter rollers - 2 in front and 4 in the back. This set up has a lot of resistance. I can only use my big ring for short intervals (a couple of minutes max). I like them a lot.
A drawback is that the resistance does not increase at a consistent rate when you increase your cadence. Although it gets harder to pedal when you pedal faster the increase is not the same as if you were on the road.
Also, Kreitler’s Killer Headwind is an adjustable roller attachment that supposedly duplicates anything from a tail wind to a “killer” headwind. (I have heard that it can get pretty noisy though.)
David K
I have a set of 2.25" Kreitlers (no additional resistance unit).
It’s possible to sustain 400+ watts on those with 53 x 13 or 14 gearing. The other important variable with small diameter rollers is tire pressure. Big difference between resistance with 90 psi tire pressure and 120 psi tire pressure.
It appears Kreitler did some testing recently and has provided the info you desire:
http://www.kreitler.com/trainer_wattage.php?pg=wattage
I have no knowledge of the testing protocol; I am sure they would provide if asked. These data may put to rest the notion that rollers are not suited for intervals and such due to a difficulty in reaching big wattage.
Since it has been snowing in Cleveland for the past two days, it looks like Saturday’s ride will be indoors. I have a set of dyno-mytes and a SRM. I’ll see how my results compare to those posted at the Kreitler site.
Jay
A power/speed comparison for a few different models.
http://fixedgearfever.com/modules.php?name=Roller_Tests&op=resistance.htm
