Roll out on CT, with Cervelo
For some stupid reason the rollout on the computrainer with the cervelo causes it to roll down slower then it should making courses impossible.
Does this happen if the back triangle is too tight? I am thinking that with it tight it causes the roll out to take to long acting like it is tighter then it should be.
I losened it up a bit not sure how much that will help though. I’ve actually had this problem with both p3c i’ve had, but not the T-12.
Any suggestions?
Grant
what are you talking about??
Sorry its late. I mean to calibrate it. it calibrates it wierd.
I.e. I tried to do the AG nationals course from last year and i was doing 250 watts to go 15 mph… which obviously would be a little overkill.
Grant
I dunno…the speed never seems too accurate for me, so I never even pay attention to it. 250watts to go 15mph is definitely odd though. You should only tighten the roller enough so that your tire isn’t slipping.
yeah its accurate to what its actually spinning but not what you would actually be going. Im wondering if its teh actual skewer being overtightened that is causing it.
or the bolt things holding the skewer.
Grant
I use my P2C on the CT. When I calibrate it I shoot for a setting between 2.2 and 2.6. The speed and watts used while on the trainer are pretty much right on when compared to riding outdoors. The only thing, which I am sure happens to everyone, is that the hills on the CT are much tougher than in real life. On a side note I did email Cervelo asking about any dangers of riding a P2C on a trainer and they simply said it was made to handle much more stress than what any trainer could produce.
"i was doing 250 watts to go 15 mph… "
Did you do the whole course? Maybe there was a headwind for the first 1/2 and for the way back you would have been doing 40 mph at 250 watts…
Yes it does which is why its wierd. I did loosen the skewer though so hopefully that fixes it. It was too laste last night for me to try it again.
Grant
haha no. i wish i could do 250 watts for that long. Wind was turned off so it should have effected it.
Grant
