If you have been previously entered into the athlete list simply click “Modify Athlete”. On the next page use the pull down to select your screen name and on the right select “IMC 2007” and then “go”. You should then show up on the list below.
If you were not previously on the list simply click “Add Athlete” fill in your screen name and other info and “Go”. Then follow the instructions above to add yourself to the race…technically you should show up here when you reload the page.
If all the cards fall into their place I should have my version of an awesome race. If not, I still know I’ve had a great training year and I’m happy with what I’ve accomplished.
My goal is to make the very best of the race that I have.
Good luck everyone and enjoy your taper! The hard work is done.
Thanks for putting this together. I’m really looking forward to Penticton this year. This will be our 4th time up there and probably my last for a while.
thanks this is nice. Only may be embarassing due to ruptured quad in March. I registered & it say so but when does ones screen name get added to the worksheet.
