Great advice everyone, I really appreciate it. For now, Roka’s are getting thrown way back in the closet. Heading to pool tonight and doing 50x50’s on :60 in order to start re-training myself. Oh yes, and my simple speedos will be covering my man area.
I wouldn’t swim using that philosophy. Or at least not exclusively. Too much drag is not better than too much resistance.
For what it is worth, the ROKA folks specifically warn against this.
Last time I wore lava pants I did 12 x 75s on 1:15 and held :49. In meters. Swimming crack, no doubt!
I wouldn’t expect that too much drag is any better than too much resistance either. ![]()
I wasn’t really referring to drag specifically. I was speaking more to mental toughness and the psyche - it is the law of humans, we are inherently lazy and will take the path of least resistance. He said he went to the front of his lane in masters which means he probably wasn’t being challenged in the same capacity even if he thought he was.
If you want to be efficient and fast use the equipment and training tools that makes you work harder.//
No piece of equipment makes you work harder. Only your brain can do that. Every piece of equipment that i can think of can make you work harder if your brain directs your body to do so. If you pull hard on paddles with a buoy, then you are working harder, if not, then you are not. IF you swim hard with a snorkel, you will get less air, thus working harder, if not, then you are not. If you swim in a drag suit hard, it is harder, if not, then you are not.
Rinse and repeat for every piece of equipment you can imagine. Now some pieces allow you to swim faster and some slower( wetsuit vs drag shorts). That is a different discussion. But if you want to simulate what happens in a normal triathlon swim, then the wetsuit swimming would be much more beneficial than some drag shorts. Wetsuit/ pull buoy puts you up in the position you are going to actually use your muscles in, drag suit put you down in the water where you never want to be. My advice is if you want to strengthen you pulling muscles, which the drag suit certainly does, use paddles instead, they will force you to pull up on the plane that you will race on.
I use mine once a week and my times are better. Just don’t get too dependent on them.
Totally agree with Monty.
Only you can make it tougher or harder or easier. I wear Roka shorts once per week to swim on the days that I do 2000lcm with paddles. It lets me focus on my lats, traps, and shoulders and assess what I’m doing so I don’t destroy my shoulders. Not easy.
I use fins only when doing dolphin kick on my back or for fast sets of 50m fly. Not easy.
500m warmup in speedo. Pretty easy.
It’s all relative.
I actually use mine every swim. Number one reason is because they make we want to swim more. I never looked forward going to the pool before now I do and get there more often. All of my races are in a wetsuit so I figure why not. I make sure I’m working hard and I actually concentrate on my kick more. Use them as much or as little as you want but for me If I get to the pool more because of them I see that as a plus.
A bit confusing for me.
You are faster with the shorts, but slower with a pull buoy.
So the next question would be.
Do you do kick sets and have you lost speed with those.
Do you kick when you use the Roka’s.
You say you are slower with a pull buoy and I assume you don’t kick with a PB
It could be a consideration that you have a good kick and you have lost power in your shoulders.
You might have gotten faster initially, but somewhere along the line you eased up and lost conditioning while still pulling those times.
People who are strong in the pull usually speed up with a pull buoy. You don’t.
The next question would be whether you swim because it’s part of triathlon, which is the principal reason you would buy Roka’s. They help mimic the body position of a wetsuit and allow you to train more properly for Tri swimming in wetsuit races without overheating in a pool. Or did you buy them so you swim faster in practice. So pool or pond?
I too swim in Roka shorts, I warm up without them, then switch. As a former competitive swimmer (many moons ago) I can say that the stroke difference is significant between wetsuit swimming and competitive pool swimming. So pool or pond? Swim for the event.
It’s a tool. I’m sure you know the saying
Phog- I will try and answer your questions and add a little more info
–I am a FOP sprint triathlete, and 4:40 HIM.
–I never do kick sets.
–I do kick with the Roka’s. But my kick is ALWAYS horrible.
–If I kick with a board as my only toy, I barely move.
–Your right, I solely bought them to kick ass in practice (seriously).
–On video, I have a decent EVF, and decent pull (lots of paddle work and 24 Hour Fitness), but again, with speedos, I have a huge struggle getting hips on top of the water.
But with Roka shorts, I am a God in my Masters lane. With speedos, I am an impotent fool.
Ofcurse it’s evident if you don’t work harder regardless of what you doing you will not improve :). I think the point here was towards restance training. And swimming with a pull bouy and paddles is a great workout to isolate your upper body and work on your upper body strength.
And you are very right about some of the drag suits. I came from a swimming background and it always hated them as they put me in a off center position dragging my hips down. So I designed a drag suit that does not do that. It allows you to retain proper balance body position as it distributes the drag over larger portion of the swimmer.
Rocket Drag Suit
http://www.rocketsciencesports.com/shop/man/swimming/swim-drag-pants-unisex.html
This is an interesting thread as I’ve been looking at buying a pair of these. Right now, I swim in either Speedo’s or regular old board shorts. I use the board shots because they operate as a makeshift, half-assed (read: cheap) drag suit. 100M times are appx 10 seconds slower in them. Seems to be a lot of criticism of the Roka’s in here though. Do they fall into toy category? I’m not so sure but they certainly seem to be an aid. Curious on thoughts if they are worth the money.
Well, if you don’t have a good kick, it seems very strange that you are so much slower with the pull buoy than without, yet faster with the Roka. Just seems like an odd set of data, not sure what to make of this. In any case, perhaps if you could just swim more and try to focus on keeping your hips up, and pulling harder, then your speed both with and w/o the buoy will increase. Maybe try an off-season swim focus, with increased yardage.
I’m pretty sure the better solution would be to have a coach help you with your body position rather than use these at all. I can’t speak for how this helps MOP or BOPers in dropping 5-10 minutes off a swim time. But I’m pretty sure they wouldn’t help someone who was already FOP and trying to take a minute or two off their time.
My advice: Ditch em and fix your body position. If you know it’s bad, then stop letting it be bad.
But that is just it…it is a tool for helping fix it. They clearly should not be used all the time, but I can tell the difference in how my lower back engages and my core tightens when I use them. I then try and repeat that sensation without them…even though I am far less successful.
Hmmm that’s interesting then that they’re not working for you, but they work other people. Has your kick gotten lazier as a result of your hips having more artificial lift? If you don’t practice kicking hard WHILE SWIMMING, then that’s going to really hurt when you do TT’s. Just a thought.
I’m saying the exact opposite…they ARE working for me. My swim times have improved, but i am much slower without the Rokas and I don’t feel as “engaged”…but I know now what I am striving for.
I hate to be the bearer of bad news.
You’re not a god, you barely beat me and I’m 66 with a gamey leg (swimming meters, less turns).
So if you are leading your Masters group, you need a new group, faster pastures mate.
(you’re over an hour faster than me in an HIM so thank the other gods you can ride and run)
As for why the Rokas work so well for you, take it as a bonus and stop using them for a month or three.Then go back and see what happens.
Because once you are in the race it’s about how you use the advantage that the wetsuit so obviously gives you.
Which is what the Rokas are for.
I really like my Roka shorts. I use them 1 a week at the most, for shorter/faster swims. They have helped me improve my cadence, thus improving my overall speed. I has been a positive cycle. I went from a 45min HIM last year to a 36min HIM swim this year, without swimming more meters. The only change from my 2013 race to this year were the Roka shorts, same old wetsuit, one year older…This is a HIM in a lake with similar conditions year to year, not in the ocean were it can change more from year to year. I’ve been so happy with the shorts, that i’m considering upgrading my wetsuit to a Roka Maverick Elite.
