Rockman HIM vs flat half Run course question
for those of you that have done rockman, and a flatter half run course, what did you see as the time diff in the two?
from course alone, not extra training.
I did Rockman this year and ran just under 1:40 and then went 1:27 @ Spirit of Racine last week. I would say that I am in better shape now and the weather was better but I would say 10 min. would be a fair difference. The Rockman run course is stupid hard (harder if they don’t have enough aid stations again)
the race i have coming up is DEAD FLAT. biggest hill is like 10 feet, makes racine look hilly.
this is the type of thing i like to hear.
last year at Rockman went 1:30:2?. went through the first 2 miles of rockman in 15:00 and ran a negative split. My testing indicated I was in ~ 1:28 to 1:29 shape.
8 weeks later ran a 1:26:00, with 3 walking pee breaks and 1 stopped to pee break. ran each 5k faster then the previous 5k, rolled the first half of the run in 1:28:30-1:29 pace, ran the last half of the run in ~ 1:23 pace. Testing indicated I was in about 1:25 shape as did the latter half of my run.
8 weeks later in even better run shape ran a 1:31 and no negative splitting, but rather stupid riding that caused a meltdown. Testing indicated I should have been able to run about 1:24.
i ran (i think) a 1:44 at rockman this year, but missed a TON of running leading up to it due to a stupid injur (dropped an outboard motor on my foot at work 8 weeks out). prob ave 15mpw on a good week in the 8 weeks leading up to it.
hopping with a flatter course and consistently in the 30-35mpw range for 3 months that helps a bit.
Hi. At Rockman this year I ran 1:41:30, and at Racine last week I ran 1:41:38… which I know yes is quite sad and embarrassing actually. BUT, I had a very good run at Rockman, and I’ve been riddled with injuries this month and had to stop several times giving myself some massage on some tight hamstrings, it was a struggle at Racine. Rockman I was solid all the way through, so I’m guessing you should be at least 5 minutes faster or maybe up to 10 on a flat course.
