When I see a Tri-bike listed it sometimes mentions where it is ‘UCI Compliant’ or not.
I am guessing that the bike can or cannot be used in a UCI sanctioned road race based on it’s status?
UCI sanctions road racing right?
I cannot figure out whether my bike is UCI Compliant - 2006 Kuota Kalibur - do you know?
Now if it ‘is’ compliant then I can use this bike for TT events?
*HOWEVER - if I slapped a set of road bars(drop bars) on the bike(Yes I’ll dial the fit in properly, thanks for your concern rollz eyez) could I use it in a ROAD RACE? The idea here is to try out a beginner road race cat 5/4 or whatever it is.
These are OCA sanctioned races - Ontario Cycling Association.
Thanks in advance!
yes the kalibur is uci compliant
even if it wasn’t you could use it in any race unless it was a qualifier to nationals or worlds or something
and yes you can use it in a tt or road race.
If you mean time trial when you say road race, then the answer is yes, it can be used in a UCI-sanctioned race as long as the setup doesn’t violate UCI rules (5cm saddle setback, no front disc wheel, etc). I believe the meaning is that the bike fits the UCI’s form requirements (3:1 or lower aspect ratio, double diamond construction, etc)
To use in a road race, you’d have to change to drop bars like you mentioned. The tricky part could be getting the reach right given that you may have to push the saddle further aft than you currently have it set for triathlons. That said, the only measurements I’ve seen locally at mass-start events were gear development checks for juniors. YMMV
Canada is a bit more strict than the US. Best bet is to check with your local Head Ref. In general the lower the level of the race the more lenient they are. If its a local race you’ll likely be fine, if its a national race they may be more picky. I doubt you’ll have a problem.
