Ritchey Adjustable Stem Experience Updated with Pic
Does anyone have experience with the Ritchey adjustable road stem? Just put one on my TT bike. Seems solid, but thought I should ask.
Ric
Edit:
Here’s a shot of the stem installed on the bike. Worked great.
http://i12.tinypic.com/4de8oqq.jpg
Mine is almost 1 year old. So about 5000 miles on it. I’m loving it. I like being able to make small changes over time and in one case I went down a little too far and had no problem bringing the front-end back up a notch for the next ride.
It’s definitely solid. No way on earth the adjustable part can slip.
I’ve been riding with one for 4 or 5 months. It’s rock solid.
Thanks. A track rider told me he busted one. I’m just doing TT and don’t think I’ll put anywhere near the stress of a track race on it.
Ric
Ditto on being very solid. The only drawback I found is that to change the angle, one has to completely disassemble it. You need to mark the two halves before taking it apart so you know how to put it together in the right place. But that design makes it really robust.
Yes, I found that out yesterday. I have it positioned and won’t need to change it. Liked that it had to come completely apart. Felt very solid to me. Just wanted a little more reassurance that it won’t snap on me.
Thanks,
Ric
I have a Nashbar knock-off. It works great–solid as a rock. Until I get my position finalized (I’m slow). Eventually I’ll get a 30deg or so, 12 cm stem that I can point downwardly to compensate for the long head tube on my softie.
Loosen it, whack the bolt from the side, this will disengage the teeth. Rotate it a little and retighten. No need to disassemble.
Agreed, I used to think I had to take it apart also…not so.
As for durability, I beat the shit out of mine on my 'CX bike and never a peep from the stem. You’re good to go bro.
Well if you’ll cross with it, I can TT with confidence.
Thanks everyone for the responses. Will post position pics when all dialed in.
Ric
Bump, new pic at the top.
Yup, I have one as well on my TT bike and it is WAY solid, although I hardly crank on the thing like a road bike in the hills, but it sure feels like I could. I agree though, a pain to disassemble to adjust, but I think that is what makes it so solid with all those “teeth” on the stem clamp part.
Is anyone using this stem on a 1’’ steerer? any problems?
thanks.
I have one on my P2K with a 1inch steer. I have been using it for over a year with no problems (with a shim of course).
I am trying to install this stem on a P2SL; the stem seems solid before putting it on the steerer; once there and everything tight, it is possible for the handlebar to tilt to either side. there is about half a millimeter of play where the two parts of the stem connect / where the bolt that tightens the adjustable part is. i hope that this is not how it is supposed to be…
could soemone please confirm…
my guess is that the shim somehow corrupts the stability; maybe it is the specific one that I am using, so I will try another shim; maybe I am making another mistake though…
any thoughts are appreciated. thanks
That doaesn’t sound good. I got the shim when I brought the stem from MDT in the UK it has a lip on one end and was a pretty tight fit so there is no room to move. http://www.mdt-products.com/
Just an update on the stem:
I went to my LBS and we tried another shim (one without a lip): no change;
we then put the stem on a 1-1/8’’ fork - still some play in the adjustable part - what I thought was the effect of the shim, was also happening on the 1-1/8’’ steerer w/o shim, the adjustable part, though tight, still had play;
He then ground some part off the middle of the adjustable part - all solid now.
Looks like you could have just used a regular Ritchey stem available in 6deg, 17 deg, and 30 deg.
If you remove the tall cone spacer you could get rid of much of that bulk.
That said, the Ritchey stem is pretty much bombproof and if you are not a gram counter, its perfectly suited to that application in my eyes.
-SD
