Somebody asked me the other day if I have something against Reynolds forks. This was based on a post I made on this forum. I had written that there had been some problems with Ouzo Aero 700c forks on P3s, but my answer was a bit short due to limited time and the fact that I had written the long version just days earlier.
So in case others have gotten the same incorrect impression, I just want to say I have nothing against Reynolds forks (I think they are very well made) and do recommend them from time to time (no pun intended). My problem is with 40mm rake forks being put on Cervelo TT/tri bikes, and with the Reynolds Ouzo Aero being a popular fork and having a 40mm rake, this is the problematic combo we hear most about. But it also applies to other forks with a 40mm rake. So there is no problem putting a reynolds fork on your Cervelo, just make sure it’s not a 40mm rake but a 43mm (for 700c).
Personally I didn’t like the reynolds pro 1" carbon steerer fork. I installed one on my litespeed vortex this spring. There where two things I didn’t like.
there was more vibration transmitted to the bars with it.
the torsional strength (for example when you put the front wheel between your legs and twist the handle bars) of the carbon steerer tube was much less and somewhat disturbing.
I went back to the original setup a few weeks ago using threaded Kestrel carbon fork with steel steerer tube and am much happier with it although is slightly heavier.
This falls back into my post from a few days ago pertaining to seat tube degrees. Sometimes the best fork is the fork made or the intended OEM fork. So you can save 1oz on a fork…you can save more than that by eating more bran.
I also did not care for the Ouzo Pro on my Ultimate or Vortex and went back to the OEM Time HFC forks on each…however I love the Ouzo Pro on my Softrides.
I’ve yet to come across a Ouzo Pro Aero with a 43 mm. I checked the Reynolds website and they list it there, but have yet to se retailers carry them. Every retailer i see just caries 40 mm. Anybody know of a retailer that carries one in a 43 mm?
I was told retailers had to special order the 43mm offset fork and it would take 3-6 weeks. I went with an Alpha Q instead over a profile BDC. It took 4 days to get.
