Reversed front brake behind forks?
I see MJ runs one on her Giant and also see in the new mag that Argon has theirs on the inside. Who else rides like this? Wind tests? I used to run my rear like that on my BMX but that’s going back a few years.
Well, not that I’m anyone, but I’ve got one of the Oval Concepts front brakes and quite like it.
You can get more info here:
http://www.ovalconcepts.com/productsDetails.php?idProdotti=28&idProd1=1
I couldn’t get it to work with the Wolf fork and first went with a spare Reynolds fork and now have an Oval Concepts fork.
Does it make a difference…maybe…probably… Do I notice it, not really. It’s same with the fork, don’t really notice a difference, but I’d like to think things like this will add up and overall make a difference. But, in any case, I sold my ZG front brake and made money after getting the OC brake and needed to get a new fork, so I’m content regardless.
Let me know if you have any other questions I can help with.
-Chris
LOL - Rant on…
I would also presume that you have taken care of your helmet strap, your race number does not flap in the wind and you do a VERY serious job of being sure that you are in the aero position 99.9999999% of the time. One second not in the aero position will mitigate any gain by moving your brake to the rear of the fork.
Rant off…
I wonder if my Record brake will work behind the fork.
That would apply to sooooooo many other aero products, so it’s sort of a fruitless rant, isn’t it?
CHRIST MAN!!! Dont let the FACTS get into the way of our spending habits!!!
OK sorry… spend AWAY!!!
If i remember correctly Gerard did some tests for this and said on here a while back that he discounted it. In my (out of wind tunnel) academic judgement, I would rather have a turbulent component which can then have its air cleaned up by a foil behind it (conventional brake arrangement) then have a nice smooth foil finished off by then having the brake in it’s trailing edge area dirtying everything up. This all has a lot ot do with the downtube as well though and how it all marries together.
It’s an interesting point that the new Felt had it’s rear brake repositioned but they left the front one as it is…
It is very tough to find a condition where the brake being repositioned is of any benefit. Real world conditions seem to have the best airflow with the front brake leading the way, not trailing behind it.
Did you know a row boat has less drag (fluid-dynamic) going backwards?
Most of the time having a clean trailing edge will supercede the leading edge. Now if you could stuff the brake inside the fork you’d be on to something…
…oh wait, I’ve said too much.
Like this ? Canyon has a prototype with the brake stuffed inside the fork
http://www.canyon.com/technologie/i/teaser-005.jpg
http://www.canyon.com/technologie/i/details005-neu.jpg
Drool
I remember seeing that in the Interbike threads (and in my dreams ever since) That is the sweetest machine.
that is one way, I’m not sure the cycling community is ready to jump on hydraullic brakes with proprietary levers and aerobars.
People said the same thing when MTB’s had the options of Magura’s 15 years ago. I’m amazed it hasn’t happended already…
In the Tri bike fraternity it would take an innovator with the production clout to really have a go at this though…
MTBikers aren’t part of the cycling community???
I didn’t know!!! Damn!!!
MTB bikes don’t use aero bars, what is your point?
Can you suggest one viable option for hydraullic brakes AND wheels for the road?
I reiterate, the cycling community is not ready.
-SD
