I picked up a run injury in the begining of December - Achillies and knee on left side. I picked up a cold about the same time so decided to just rest it (use R.I.C.E). Unfortunalty the problem was still there when I started training again 2 weeks later. Finally decided to see the Physio and found out it is biomechanical problem so the physio has given me a few stretches and exercises to sort it out. He told me it is ok to run on. So far I can run for about 30mins before the achillies tightens up to the point where I feel like I am running with a limp. I tried doing 2 runs on Wednesday one 30mins and one 10min jog and that seemed to work well.
Is adding frequency but keeping the length of each run down an effective way to build up strength whist remain injury free?
All personal experince, I’m no expert, but I find that the most important thing is to keep the runs short enough that you don’t get any pain. Make sure you stop before the pain starts. When first coming back I’ll keep the frequency down to give lost of rest/heaing time (2 runs a week) and then build up the duration and frequency SLOWLY.
Add water running and daily stretching and you should be on the right road.
Again, all personal experience so some more knowledgeable folks can probably give a better line of thought.
Check out TPTherapy.com, they’ve just come out with a guidebook the Ultimate 6 performance enhancement points for runners. It concentrates on the areas of the body you want to work on to have good biomechanics, they also have some stability PODs that allow you to work on your core as it pertains to running. All their products give you the ability to bring therapy into your own home.
Check this out about injuries on the left side of your body:
Here is an running injury recovery schedule that I have (unfortunately) used several times with great success over the years.
DAY TIME INTENSITY
1 10 MIN. EASY
2 12 MIN. EASY
3 15 MIN. EASY
4 12 MIN . EASY
5 18 MIN. EASY
6 20 MIN. EASY
7 25 MIN. EASY
8 20 MIN. EASY
9 25 MIN. EASY
10 30 MIN. EASY
11 25 MIN. EASY
12 DAY OFF
13 20 MIN. EASY
14 25 MIN. EASY
15 30 MIN. EASY
16 25 MIN. EASY
17 35 MIN. MODERATE
18 40 MIN. EASY
19 30 MIN. EASY
20 40 MIN. MODERATE
I just resumed my regular running schedule upon completion.
How much frequency? Right now, I’m running about 4x per week and 3 faster (8:30min/mile) or 4.5 slower (9:30min/mile) miles each time. I’m not having any problems so far but I’ve been doing this for only 3 weeks now.
