Retul Fit Done: Now help me select a frame please!
Had a Retul Muve fit done a couple weeks ago to try and get an idea of stack and reach.
I’m around 176cm tall and currently ride a 53cm Pinarello road bike. (I know you cant tell frame size from just my height but its all I have on me)
Retul measurements came back as Frame stack: 533mm, Frame reach: 415mm
The stack puts me towards the medium and large frames if I’m reading the ST database correctly which I would never have guessed (pretty sure a large frame would be way to big for me)
Any tips on:
  1. does stack and reach seem reasonable?
  2. frames I should be looking at?
i m not sure how you read the data base but you would fit easily on a 54cm cervelo p2 p3 p5…
That would be a easy fit option. There is most likely a lot of other option of brand as your data have noting special or abnormal. you will fit most 54cm (medium size) in many brand.
Thanks.
Called myself TriNewbie for a reason
Do you happen to have your pad stack/reach as well?
I do but…
Original measurements came back with odd frame stack and reaches (561 and 373). When fitter went back to remeasure my tri bars weren’t on any more so I dont really trust the new pad stack and reaches (574mm and 488mm for interest sake.)
OK, frame stack and frame reach are good and all, but that also assumes the following:
1.) You’ll use the same stem length/pitch as you did for your fit.
2.) You’ll use the same basebar/aerobar as you did for your fit.
3.) You’ll use the same number of spacers as you did for your fit.
Now, of course, you may need to play around with spacer/stem depending on frame choice (say, if you’re 1 cm long on frame reach, etc.)
Example: a newer B-series Felt in a 54 goes with 536/405. Go a cm longer on the stem and you’ll be damn close.
In that realm, then, you’ll also look at Kestrel 4000 in a 55, Cannondale Slice in a 56, new P2/P3 in a 54 or 56 (depending on which way you want to go with stem/spacers).
Did you ask the person who did your fit if they have Retul bike data base? He should be able to print out some suggestions for you.
Yip I’ve asked…waiting for suggestions to come back
