Replacing Powertap Pro+ battery in Hub
The battery in my Powertap Pro+ hub needs to be replaced and I did not receive the hub tool to remove the cover.
Any suggestions to remove it other then going to bike shops?
I’ve used a rubber strap wrench…
I’ve been able to remove at least one of mine with my own hand (assuming you haven’t tried). Otherwise it might be tough. As Tom suggested, I think your best bet is a rubber-strapped wrench.
Your local bike shop should be able to help you. Otherwise, give Saris a call.
Call Saris.
As good as Saris customer support is, they can’t do anything for you except send you a replacement tool (which they will do for free). I know from experience. :slight_smile:
Thanks, Chris
I’ve never been able to get the cover off using Saris tool. Either I’m doing it wrong, or the thing is completely worthless. I’ve used a pipe wrench over a towel to change mine. The strap wrench sounds like a better idea.
Thom
