Replacing Campy cables: how do I get the ferrules to fit?
I’m recabling my road bike, and I can’t get the cable ferrules to fit over the housing. Should I just trim off the housing and give a couple wraps of electrical tape to get the end to fit, or does someone have another recommendation?
Thanks. Oh yeah, I’m using the Campy cable set. Why do they only supply 4 ferrules, when you need 6? Sigh.
Working from memory, but the supplied ferrules are only for the shift cables which are a smaller diameter than the brake cables (maybe you’re using the wrong cable?). You should have two shift cables, each of which has a ferrule already attached - this is the end that is inserted into the shifter body. You then use the supplied ferrules on the ends that go in the braze-ons…so on the cable ends at the down tube, and on both ends of the cable leaving the chainstay and entering the rear derailleur. You need brake ferrules for the brake cables, but not on the ends that insert in the brakes - is annoying they don’t supply brake ferrules!
Belated thanks: I had indeed swapped the housings (duh!) Finally cabled it up yesterday. Ah, perfect shifting again :slight_smile:
