On Sunday I had a 4 hr ride turn into a 5 hr ride and was WOEFULLY unprepared for the distance. I burned about 4000 cals on the ride and only replaced about 1500.
How am I going to replace 800cal/hr on the bike? Not to mention what I am expending in the water and the run.
I’m sure some others will chime in here, but under the best circumstances, you can only expect to be able to replace about half of the calories you burn on the bike and less on the run. Practicing your nutrition can help you determing what works for you. Keep bumping up the calories/hr, you’re stomach will probably let you know when you’ve reached you limits. I weigh about 150lbs I can do between 300-350cal/hr at IM pace, less for harder efforts. Maybe start at 250/hr and work your way up.
I’m definitely going to have to start going up from there.
Why do you assume more is better? Did you truly bonk or were you just not trained for the distance you did? Don’t assume that replacing more cal/hour is necessarily better. Everyone has to find the right balance that works for them. Too much is sometimes worse than too little. Some good info on the Infinit website:
Any suggestions?
How did you determine that you burned 800 calories per hour? That’s a lot for anything but a high Z3/low Z4 effort.
At a Z2 level, probably only half or so of those calories were from carbohydrate stores. The rest was from fat. So, you only burned about 2000 carbohydrate calories (assuming your 4000 guess is near accurate)
If fully topped off, your carbohydrate stores can supply up to about 2000 calories.
Eating a good breakfast before can help, for sure. 4000 calories for 5 hours at zone 2 seems a bit excessive - I doubt you burned that much. How much do you weigh?
I highly recommend anyone asking these kinds of questions to go to Hammer Nutrition’s site and looking in their knowlege section. I think they call it knowlege or library. Those guys know more about nutrition than just about anyone, at least about how it relates to sport. A couple of quick pointers (theirs not mine, but they have worked for me)
Don’t eat for three hours prior to exercise. This especially applies to races. A few people have already noted you are trying to train your body to burn fat and eating within the three-hour window reduces the effectiveness. Not a big deal for day-to-day efforts, but I really try to stick to this for long days and races. A gel right before you start will not matter, but not more than 10 minutes.
Learn how much you need to drink and not more. If you have to stop to pee two or three times during a long ride or race then you are drinking way too much. 16 to 24 oz per hour in warm weather is about the limit.
the fat I’m already carrying or an outside source? haha
I’m not carrying all that much…do you have a preferred food that’s high in fat and would be a decent thing to take along on rides?
Yes you are.
Let’s do a thought exercise. Say you weigh 150 and have 7% bodyfat. You have around 10lbs of fat. 10lbs of fat is comprised of 35000 calories.
You had plenty of food with you on the ride, it just seems as though your body wasn’t ready for a 5 hour ride yet. If you wait a week and do another 5 hour ride it will be far more pleasant and then you’ll see how quickly your body responds to this type of training.
