Reid is much steeper than Macca
!(C:\Documents and Settings\iseliw\My Documents\My Pictures\macca_reid.jpg)
http://http://www.triathletemag.com/gallery.cfm?gallery_id=136pageID=1735publicationID=92
Sorry guys, I have been trying to post the picture of Reid and Macca in the bottom left hand corner…
http://www.triathletemag.com/gallery.cfm?gallery_id=136&pageID=1735&publicationID=92
Interesting contrast in styles. Macca looks “big slammed” slide well back on his seat. Reid is on a 76 degree custom frame from what I understand, but is well forward on the seat probably putting him 78 degrees or better.
http://66.77.216.76/exec/triathlete/galleryimages/macca_reid.JPG
Time for class…
This first time you tried to paste the link you copied it to your local drive and put up a link to that - as your PC is not a web server that just will not work…
http://c:/Documents%20and%20Settings/iseliw/My%20Documents/My%20Pictures/macca_reid.jpg…
The second time you had it – however you need to make sure that you do not double up on the http header as you had done….
http://http://www.triathletemag.com/gallery.cfm?gallery_id=136&pageID=1735&publicationID…
What you want to paste in the image box is just the URL that you can get off the image or from the “view source” HTML
http://66.77.216.76/exec/triathlete/galleryimages/macca_reid.JPG…
Thanks guys :slight_smile:
Relax pal, I was just showing the difference in angles that the two ride. It sounds like you are defensive for some other reason. I cant help you with that…
No problem, I understand… I like to be one from time to time also…
Cheers…
