Recommendations - Long sleeved, thin running shirt with SPF
Heading to summer camp! Looking for some recommendations on a long sleeved thin running shirt with SPF.
Thanks!
I don’t know of any running specific shirts that fit that mould, but a surfing rash guard would do the trick.
You could also get a deSoto top & coolwings combo, which would accomplish much the same thing and be a little more flexible.
For my long runs i wear an under armour long sleeve heat gear, form fitting type shirt. It wicks, is barely noticeable on you(thickness wise) and I cant think of a better top for doing my runs in 90+degree heat with high humidity in the middle of the day. You should probably have the type of body for something of that nature though as it hugs everything and puts it all out on display…good or bad! My nike sphere dri fit shirt isnt bad if you want to avoid tight shirts but in the heat nothing beats the under armour heat gear tight fitting top.
