Recommendations for Cervelo and Power Meter?
My wife owns a 2013 Cervelo tri bike (650 wheels) with stock GSA Gossamer cranks. I was going to surprise her and buy a Stages power crank. But they only fit the 2014 and newer GSA cranks. The local bike store recommends an upgrade to Ultegra cranks? Any feedback? As well, she’s not interested in downloading data so I was looking for a simple readout - was considering the Bontrager Node 1.1 http://www.bontrager.com/model/09586 Would appreciate any input from the Slowtwitch community.
As I’m sure other will mention the benefits of a power meter decrease if you aren’t downloading your data. At the very least she’ll need to figure out her FTP to see any real value from it. Otherwise you could argue training with HR could be just as beneficial. As far as power meter options, you can easily find lists of all the ones available. For what you’re wanting they will all be similar, so it will likely come down to cost. I would imagine with the Ultegra crank you are going to have to buy a BB adapter also so that’s an added cost. It might be cheaper to get a powertap laced into her existing wheelset (you didn’t say if she had race wheels vs. training wheels). If she didn’t do a lot of indoor rides you could also look at an iBike…or the new 4iii which would work on her existing crankset.
I really would second what the poster above said. If you are just looking at the number it’s just an expensive bike computer. To get any real benefit you need to learn how to analyze the data. It’s not hard to do but it is a (small) commitment.
a 105 crank is a nice setup, they come as regular or compact, you have to buy different bearings also. I see them on ebay as new take offs all the time, they are a great crankset, easy to install and service and the stages will bolt right up. You need a small tool to tighten the plastic nut on the non drive side that holds the crank on, I have one that looks like a big wingnut that I like a lot.
I agree with others about downloading data, it’s too jumpy to make much sense on the bike and whatever device (garmin, polar etc) she uses to read the data it will record it anyway, so just download it to the garmin site or similar
You can get real benefit from using it to pace races.
If you get one that is accurate
Thanks gang for your suggestions so far. I should mention we have a Computrainer at the house and that we did an FTP test at a once-a-week Computrainer spin class.
If there was a site “understanding and using FTP for beginners” that would be great (we have done a number of Ironman competitions but are trying to figure out the metrics of power to improve.)
I appreciate everyone’s input.
Get the book “Training and Racing with a Power Meter” by Allen and Coggan. It will tell you everything you need, and it even has a tri specific training section. It even has example workouts.
While downloading is probably the best, I find that real time feedback on my Vectors is very helpful too.
I have a 2012 Cervelo P3 which also came with the FSA Gossamer crank and I bought a Power2Max powermeter and selected the option for it to come with the FSA Gossamer crank pre-installed. That way I didn’t have to swap out my bottom bracket and can easily swap between my crank with power and my crank without power. It’s a great setup for me.
I agree real-time feedback is critical. My point was that unless you download and analyze the data, you don’t really know what the numbers you are looking at mean in relation to your training and objectives.
you’re correct sir… should’ve said I agree with you, but I thought that it was implied it was such a good comment =)
FSA used the same BB dimentions as Shimano (megaexo and hollowtech 2) anyway
and so does Rotor which is a very nice crank as a Power2Max
Don’t assume that because you don’t know what the numbers mean others don’t.
How in that statement did you come up with the opinion that I don’t know what power numbers mean?
By reading your pompous post.
Pompous? I was making a factual statement. At least one other person on this forum agreed with me. You’re the one that sounds pompous.
You don’t need to figure out FTP to benefit from a power meter.
I respectfully disagree.
Do you really believe you need to know FTP to benefit from a power meter?
Knowing FTP is useful. If you want to use WKO or Golden Cheetah software you do need to know it, although most people estimate it so badly most of their data is worthless.
A power meter is a measuring devise. No more no less.
Basing training on FTP is only one approach.
Call it FTP or call it something else, you need to know to know a data point to measure against to find benefit from a power meter. Of course you can use a power meter to measure your real-time power during the ride and do nothing but know your power. But we are talking about benefiting from a power meter (i.e., improving your ability). To do that you need to do more with your power meter than just looking at the numbers - you need to have some sort of plan when you head out for a ride. You don’t have to use WKO or something else, but you need to know some type of number (be it what you can hold for 5 mins or 5 hours) and base your training off that number.
