Planning to upgrade my to a compact crank and go from my current 175 length to 180s as suggested by my bike fitter. However it’s a little tougher to find compacts in the larger sizes. Also, looking for a compact of that size that I can ultimately use with an ergomo (isis, iso square, or isis).
Value is an important factor for me in the decision.
We make two different “adjustable” crank sets that include 180 in the available sizes. This would allow you to play with the crank size some before you had a custom set made for racing. (our fixed cranks also include a 180 size option). Unfortunately, if you don’t want to train with PC’s then you would need to get the lock-out option, which if you do not train with PC’s would sort of run afoul of your “value is an important factor” requirement.
Thanks for the link but yes there is that Value thing. For that price I wonder if the 180 is worth the cost when for the like money I could go with carbon 175s.
The 38 tooth standard is an interesting thought. I’ll have to research that one.
All I know is I went from 180’s to 200’s and have averaged a 5 minutes time savings in my 30 mile hill workouts. But, most ST’s
will tell you Crank length makes no difference.
You can use a 38-tooth chainring on a standard Dura-Ace crankset, so that might be a good way to go if you can not find a 180mm compact.
Does anyone know where to puchase a 38 tooth chainring for a standard dura ace crankset?
I’m not sure how you can use carbon cranks and value in the same paragraph. The only thing carbon adds in a crankset is “bling” and that is not exactly value. I went from 175 to 180 and there was a pretty small difference. Then I came across an interesting formula (inseam in mm x .21 to .216) and decided to try 190mm crankarms. That was even better and I will never go back to shorter crankarms. My inseam put me between 184mm and 189mm so I went with 190s.
Frankly, if you need 180mm cranks I have a set that I have used with my ergomo (square taper) in the past. I also have a sport model ergomo that I don’t use either. (I know I’ve crossed to the dark side–classifieds–so I’ll leave it at that.
Whereas Shimano does not sell a Dura-ace 38T ring, any 130mm BCD chainring will work. FSA and Salsa 38T are readily available from many online retailers–your LBS can also get them if they don’t stock them.
Speedgoat.com, competitivecyclist.com, and excelsports.com are three online suppliers that I know of that have them. I am sure there are others. By the way any chainring will work on the inner ring. It does not have to be so-called 10s or 9s specific.
