I hate these charts… maybe they work for a large amount of you but I’m sitting around 280 ftp and there is ZERO chance I can ride 260 watts for an Olympic and be able to run what pace I want. Maybe I bike 260 and the faster bike time makes up for the lack of run but I wouldn’t want to test that theory.
I went through a period where I was obsessed. One attempt with a coach, and the other on my own using my Computrainer. Both times I found myself dreading my workouts and eventually burned out.
Its going to be hard, but I think those gains are realizable. Personally, from my experience, I went into it too fast and found my burnout. Maybe getting more base miles you can get some where more sustainable. Would be interested to see how the rest of the community responded.
The advice I generally get when I ask around is simple, “time in the saddle.” Just keep riding. There are a bunch of winter plans out there and some very capable coaches also that are very reasonable. Chanthony worked with the coach I had and he’s just flourished. He is also a freak so it may be weighted a bit.
I agree that 25% is wildly optimistic beyond year one. And how much of that first year is pacing is a legitimate question as well.
For those of us who’ve more or less stagnated FTP-wise, anyone else noted that their power-duration curve flattens out? My FTP seems only slowly changing, but my ability to hold higher percentages of that in a half is still growing.
You can nearly max out your <CP60 in less than a year, starting from scratch. The long distance will keep improving for ~10 years or so… or at least it can if you work at it.
Obviously it will vary from person to person but are their any standard expectations one should set?
No.
It would require a thorough evaluation of where you are and how you got there. What was your FTP when you first started to ride? What sort of shape where you in when you started (including your exercise regime)? What training have you done since you started? Ever had a VO2 max test? How old are you? Even then it’s pretty much a WAG.
Twice in my life when I started cycling hard I experienced ~70% gain in FTP in less than 6 months (180W-300W)… and very little improvement after that. So I think you can get close to your potential in 6 months or less if you are already decently fit. Might as well just do the work and find out.
Apologies. The cells in blue are inputs. They can be changed. They are specific. The cells in black are outputs–they are calculated based on those inputs and cannot be changed. Most amateurs cannot ride 70.3s at 0.88 and run a strong half afterwards. Some can.
Over the 2009-2010 winter, I followed a 14wk long bike specific program the first time using a trainer and gained 14% (Critical Power method using 5’ and 20’ tests). It had 3 phases, Improve VO2 (raise the roof), Improve Submaximal (slow glycolsis), Improve Threshold.
After taking 2012 off and getting back into the game in 2013, this past winter I followed a 12 week program as prep for an early season HIM. I gained 12% focusing doing Sweetspot and Threshold trainer rides between 60 and 105 minutes in duration. Also tried to ride once a week outside with a local roadie group.
I think anywhere from 10-20% gains your first time through a focused program is a good estimate.
Hwi did you determine your FTP? Some coaches refer to “critical volume”. How many mikes do you ride a week?
Not sure what my FTP is because don’t test.
Nov 2013 did 2 hour ride at 178 watts with heart rate of 128 bpm
July 2014 did 3 hour ride at 216 watts with heart rate of 130 bpm
20 minute max effort immediately after 75 minute hard ride (I never stopped the whole 95 min). Yes, I know it’s not how you’re supposed to do it but this was harder than any FTP test (minus a straight hour TT) I’ve seen. And I did do the 95% of what watts I pushed for the 20 minute effort.
As for miles, I tend to find that pointless when talking about volume because I ride long mountain climbs on every ride. I do about 10 hours of cycling a week (one 5 hour ez ride, everything else hard intervals).
FWIW… I’ve never been good at shorter distances. My 10k open run is a tragedy. But looking at that chart, pushing 202 watts for 140.6 and running well after seems doable and is damn close to my goal watts (196w) for my A race.
Also FWIW… not sure what the 20min column is for but when I do 20min intervals in training, I go about 290watts avg.
Using Normalized power, the charts are pretty close to where I’m at for an “A” race at each distance based on my 20’ FTP test.
Looking at it that way, it’s more realistic. And the 204w for IM is only 2watts high for me.
I’m doing an Oly this weekend and the plan is to go hard on the bike and survive the run. I was thinking 240avg… so maybe close to 260 np. I’m interested to see now.
Was the FTP test on a climb? Often times I find triathletes have trouble producing same numbers on flats in aero position they can on a climb.
I live in the Bay Area so I feel ya - it’s straight up from my house to get to valley. How long are your longest intervals?
Yep… but considering what happened 75 minutes prior. I didn’t and don’t think it matters. If I did a legit test in aero, I’m confident I’d hit the same numbers.
40 minutes maybe? 60 once in a while. Wednesday is 20 min. Thurs is 7 min. Sun is 35-40 but I don’t time it, I just ride it hard at X watts and could care less what the outcome is unless I blowup (which hasn’t happened yet). The 60 once in a while is one specific climb and I usually ride around 215-220 watts.
With all this said, I’m on the “time on the saddle” bandwagon. Just ride frequently and as much as possible, don’t pussy foot and strength will come. My A race is rollers, so I’m all about strength, not staying aero for 5 hours. I did CZ last year and trained properly for that… and fucking hated it!
When know power heart rate irrelevant or misleading.
Explain. Heart rate is my primary metric. After all it’s the one metric that links all three sports together. Tells me what’s going on with my engine. I use power, during training, as a means to gauge progress. Now for racing I’ll use power as primary if temp is on cool side but if temps spike I’ll switch to heart rate to help regulate things
Heart rate not actionable intelligence. Use RPE. Heart rate variable. Affected by many thing. Heart rate not account stroke volume only tell how fast heart.
Care to share what those programs were?Sure, they’re on the other site (BT).
First one is listed in the site’s training plans section, weeks 1 & 2 are prep and usually skipped (I never do them). Meat of it starts week 3. You can see the workouts for each week on the ‘Plan Workouts’ button/tab. I don’t know if the workouts are on TR and I only found weeks 2-4 on Golden Cheetah listing. I also have it all in a spreadsheet if you have a Kurt Kinetics trainer and don’t have ANT+ pickup, were you can input speed avg for the testing and it cross-correlates the power/speed curve for the workouts. That’s how I did it at first.
The second was part of a mentor group using TR or GC. Search “power mentor group” and you’ll find the thread starting with those words. The workouts were provided weekly so its not laid out as a readable program per se. You’ll have to scroll through the pages to find the GC files. If on TR the workouts may be on there as I believe someone was making and listing them.
