Real Design Supersonic 40's
Would anyone consider these race wheels? or should I use them as training wheels and save up for a better pair of wheels?
This Probably won’t be until next year though if I were to buy better race wheels. If this is the case should I use them as race wheels for now and buy a set of training wheels somewhere in the 300-400 $ range. What is a decent pair of training wheels in this price range?
can you get the 60s? Could always just add a rear disc cover…
Dan
www.aiatriathlon.com
No
You should not.
They are not deep enough to help.
Get at least 55mm or deeper.
A used hed3 and a Renn disc are under a grand and hard to beat for speed.
Embrace Depth
Rims 35-40mm deep will probably be good enough for road racing but for timed events you probably won’t see too much of a difference. Definitely something at least 50mm is better. Of course, if you are not picky about the small amount of time you gain with the deeper wheels, and are constricted to the budget, I’m sure they are better than standard wheels.
my buddy just got these as VERY fast training wheels with a powertap 2.4. just saw them this morning and it is a sick setup. Now i have that much less chance of hanging onto his wheel.
Dan
They came on an '05 QR Lucero (new) I just purchased. How should I use them?
I would try to trade for 60s if at all possible. But with either I would contact rich at wheelbuilder.com and get a disc cover custom cut for your rear.
Dan
It’s weird that QR specs a tri/TT bike with 40s. These are RR wheels. Need something deeper for tri/TT. Of course all depends on where you are in competition. BOP, the 40s are great wheels and upgrading won’t help. MOP, about the same, but deep wheels could shave off some time. FOP is a different story and you will be giving up time to your competitors with the 40s.
Ric
Those look cool and cheap too $65. How do they attach to the rear wheel and are they worth it for the time being?
they are held on by the cassette ( you remove and replace it over the cover) and screws around the edges.
Dan
If you can race on them, they are race wheels. They may be more of a road race wheel, but so what? Use em, maybe next season get a set of deeper wheels and use the 40’s in windy conditions, for road races or cyclocross, whatever. For training, a set of Mavic Open Pro’s, 32 hole, on 105 hubs would run you a couple hundred and be reliable and easily repaired by any bike shop.
