i decided to go back from straight extenders to my trusty “old” sbends, but now i want to install the bar end shifters from the straight to the sbend extensions. How do i do this? I got that little paper from shimano how to install them (without the cables), but the last time i tried it it went terribly wrong and i ended back at my LBS to let them do it. So how should i do it, should i first remove the cable from the FD and the back D (i have no idea how you write it. derailleur???) and then remove them??
OK i hope somebody can help me or send me to a website with a instruction manual (hopefully with pictures).
Make sure you pay attention to the note on the Shimano manual that the projection on the washer looking thing should be facing down (when the rear lever is installed conventionally). Otherwise you won’t get the correct number of “clicks”…
As you take them apart, watch how they come apart and don’t separate the parts, keep them mostly together.
Re-install as you took them apart.
Note: if you had to remove the cables. Make sure the levers are “down” to rethread them. Thats the position that aligns the holes to get the cable through.
I can change the aerobars without removing cables from the shifters. Shift into the large chainring and large cog. Without turning the cranks, shift a notch or two down. This gives slack in the shift cables and allows you to remove the lever without removing the cable. Take the lever off without letting it fall apart, put the bolt right back into the removed lever to keep it together (the lever is now dangling from the still installed cable). Remove the base sections. Change to the sbends. Put the bases on the bars. Put them levers back on the same way you took them off. DONE!!
