I’m usually the first (or fifth) person to chime in and tell someone not to buy a bike that doesn’t fit. Typically what I am advocating is to purchase a frame with the correct stack height, without consideration for reach, because I’ve never been particularly sold on concept of sitting ON a bicycle seat, and thus being forced to rely on moving the seat angle forward in order to open up the hip angle. I am 5’10" tall, but with an inseam just short of 37".
To begin with, I have a lot of bikes. A collection of bikes might be an accurate description. They are all 650c.
Aegis Trident 54cm (15cm head tube, external headset)
Kestrel KM-40 Airfoil 57cm (17cm head tube, external headset)
Softride Rocket TT Medium (16cm head tube, external headset)
Zipp 2001 Large (13cm head tube, external headset)
Cervelo P3 54cm (14cm head tube, internal headset)
Cervelo P2 58cm (15cm head tube, external headset)
Mongoose RX7 60cm (18cm head tube, external headset)
I fit on all of these bicycles very well, except for the Mongoose. The top tube is just too long for my torso, even with a forward seatpost. I used it as a road bike for several years, but now it’s stored in the attic along side the P2, which I found not to be as fast as Gerard claimed.
I have recently acquired some smaller frames for my girlfriend who has surprising TT abilities. She is 5’5", and has a 30.5" inseam.
The first bike I put her on is a 2007 52cm Kestrel Airfoil Pro. It fits her like a glove with a Profile FF seatpost to help push her forward a few degrees further than the 76 degree standard geometry. When I was building it for her, I also made a pit stop along the way and adjusted it for me using a set of Ritchey Probiscus bars that allow you to set the stem and extension length quickly and easily. I can ride this bike with no problems in the 77-78 degree range with ~105mm of stem. No power loss, no power gain at this angle compared with most of my other bikes that are setup at 82-86 degrees.
Then a couple of weeks ago I picked up a 50cm Felt B12 on eBay for super cheap. I was very excited to build that for her so that we could use the Kestrel as more of a road machine with drop bars and sti levers for going on long weekend rides, while the Felt would be a pure TT machine. When I received the frame and started doing measurements, I determined that I could make it fit me! The seatpost was extended about 2mm past it’s “maximum extension” line, but with several inches still inserted into the frame. I set it up UCI legal (5cm behind the BB) and with a 100mm stem it fits beautifully. Same thing, no power loss and no power gain at that angle. I didn’t measure what the actual angle was though.
What I want to know is how I can fit on all of these bikes from 50-58cm from various manufacturers and never really be compromising anything. Sure I put on the right amount of additional stack by using the right aerobars, but none of these bikes have ergo stems on them to make them fit properly. The only thing I have done is invest in lots of seatposts that allow forward positions, and lots of San Marco Azoto seats that allow that perfect nose position. I never lose or gain power when moving between 76 and 86 degrees as long as I stay on the nose of the saddle.
So what gives? Am I a weird special case with a highly adaptable body? Am I fooling myself into thinking that all of these bikes fit, and that I am in fact compromising something I’ve not noticed? Talk to me, fit gurus. I want to know.
