Ralph's: Wheel and Tire Recommendations?
What is everyone using for Ralphs. I am planning to use a 39/23, perhapes a disc and/or a combo with Carbon Cosmics. Or would it be better to use a 39/25. I raced in 2001 but cannot remember the course at all. I searched the forum but could not find anything on this subject.
Thx, AR
formerly Aredemann
I think the pros use a 39/23, so that should tell you something of the course. I would use the 25 in the rear for a bail out. That hill is pretty brutal. The disk is personal pref. If you are over that 22-24 mph zone for the benefit go for it. Good luck.
42/25, tri spoke/disc
I’d definitely take something for the climbs as there is at least one that’s fairly steep, if I remember correctly.
39/25 and standard aero wheels. no disc and a warm wetsuit…
It’ll likely be windy so a disk is even better. Sure it’s a little extra weight on the hills, but there aren’t many hills.
Are you sure you are looking at the right course profile? There’s an 800 foot climb in this event. Its actually a quite hilly course.
Yeah, that’s the one. There are hills, but there’s a lot of flats and false flats. (I’ve done the course and ridden Pendleton quite a few times.) It can get windy. I was very happy using a disc both times I’ve done Ralphs.
Use a disc as long as it’s sub 1000g. 12/23 will do the trick, but your legs might scream for the 25 on “the hill”. Great event. Good luck.
“12/23 will do the trick.”
Ha! I’ll have my 25. I can do without the 16.
The first hill on San Mateo Dr. is very steep. I’m guessing it’s probably a 10-11% grade and therefore I’m planning on using a 39/25. If you plan on using a 11-23 then you’ll definitely be standing during this climb. The second and third climb aren’t that bad. Since you can only do 25 mph on the Basilone descent I don’t think you’re going to lose much by going with a 12-25. I’m planning on using a disc (970g) and a Reynolds Stratus on the front.
By the way, it looks like the bridge over N. Pacific Street might be finished in time for the race so the alternate run course may not be required.
I swam at the CP Del Mar Marina (right next to the Ralph’s swim course) on Sunday and the water temp wasn’t bad at all. My P-Flex kept me plenty warm, no other cold water gear required.
Looks like rain on friday and Saturday.
Have Fun!
Good to know, especially coming from someone that’s done the event before. I actually don’t mind the hills. I was just using that profile tool they have on the ironmancalifornia website where you can click in and out all the North America Ironman course profiles and Lake Placid and Ralph’s was pretty drastic compared to the others.
42/25,
And Jason’s going to have a top-25 bike split, so don’t do what he’s doing! Bring a 39.
