I was thinking of swapping out the Wolf TT fork on my 06 P3C for either the Oval Concepts Jetstream A900 or the Easton EC90 aero fork. Does anyone know the rake of the TT fork and does anyone have any experience with the A900 or EC90 on a P3C?
Thanks for the help. Don’t know why my previous search did not show the answer :). It’s 43mm for everyone else who wants to know.
Hello Trigeekdoc and All,
http://forum.slowtwitch.com/gforum.cgi?post=1116187#1116187
From Cervélo:
The following is the answer to your question of 16-Dec-2006 11:08:36.
Question:
Hello Support, What is the maximum steer tube length for the Wolf SL Fork when used in a P3C size 54?
I am thinkiing of buying a new fork that will be lighter than my current Wolf aluminum steer tube fork (550g) for my P3C.
I am using my P3C for Ironman triathlons. My front end set up measures 210mm from the fork crown to the top of the steer tube.
How does the Wolf SL carbon steer tube (about 350g) compare for aerodynamic drag with my current Wolf fork?
Please comment and advise.
Cheers,
Neal nealhe@cox.net
Answer:
Hello Neal,
The Wolf SL gives you a maximum ideal stack height of 3 inches above the top of the upper headset bearing (ie the top of the head tube).
If you are above this point you can always flip your stem over to get some extra height as well as using the 2.5 cm aerobar risers that are included with the bike.
Another option might be to go to the Wolf CL. It is about 100 grams lighter then the Wolf TT but has the same lower as the Wolf SL and is priced $100 less then the Wolf SL.
The Wolf TT is a very fast fork but the Wolf SL and CL are faster yet.
You will only save about an additional minute over an Ironman with these forks but for those who are looking for the fastest bike the Wolf SL /CL are very popular upgrades.
Thank you for your support.
Sincerely
Chris
Cervélo Customer Support
