Racking larger bikes - Does this happen to you, too?
I ride a 58cm Dual. Not a huge bike, but certainly larger than most in transition. I also use PD T2 Wing base, T2+ extensions and an Aerodrink with bracket.
I prefer to rack my bike by the brake levers because I believe it to be more secure (can’t get knocked off easily) and because I believe it’s not as hard on the saddle (the leasther that wraps under the sides getting torn up). I use an Arione, so the saddle is fairly minimal to begin with.
However, at a couple of races last year, I experienced difficulties in racking my bike like I prefer.
In the first case, the rack top bar was thick enough that I had to use a little force to push my Aerodrink back a little (and the bracket was mounted back as far as it will go) to get the bar into the brake lever slot. Not a huge deal, but definitely took a little more thought that I would have liked.
In the second case, I had my aero extensions mounted under the base bar, which interfered with racking by the levers and I tried to rack it by the saddle nose. However, the rack was not tall enough to roll my bike backward under it without tilting the bike to the side to slide it under. And, then, the back wheel was actually touching the ground with it racked (ie. it wasn’t really hanging, just sorta standing there). I kept it from falling over using my transition back against the back wheel. But, it was a little shady and I was worried about it falling (or getting knocked) over the whole time. And, if someone would have set up close to me, I may not have been able to “angle” it to get it out from the front.
I’m just courious if anyone’s run into these situations and has a solution.?. I have a Minoura behind-the-saddle bottle holder that I could use w/o bottle holders and just hook that over the rack. But, there has to be a better solution.
I plan to use the extensions under the base bar this season, so, unfortunately, the brake levers are out of the question.
Anyone?
Thanks.
Steve
sorry…I have the opposite problem. My little 48 bike/650 wheels usually just dangles from the rack, not touching the ground at all!! I get nervous about that on windy days…
Ditto. My Jetstream is far enough forward that I can (barely) hang the bike by the brake levers; they sorta just sit on the bar, rather than go all the way around. The worst is when I’m first on my rack, and it looks like I can rack under the nose of the saddle without having to tilt it. Sure enough, after everyone else racks their bikes, the bar sags so much that I can barely even get the bike out. Never been able to do it that way.
Steve,
You have too much time on your hands.
Happy New Year to you!
Sorry to hear about the bad luck people in this thread have been having with regards to racking. The HSBC triathlon series up here in Ontario addressed that very problem this past season. I built racks for men and women and the Kids of Steel (about 4 inches of vertical height difference between each rack) and then they went out and got all new cross poles with smaller diameters. It was a lot of work on my part and a fair bit of expense on their part but the end result looks awesome in TZ. The best solution then is to come on up here and race…at least you won’t have troubles racking your bikes no matter what size they are.
I’ve actually done a few races in Florida where it was mandatory to rack your bike with the seat. The problem is my seat is alot higher then the rack. My bike doesn’t even come close to being able to rack with the seat. I had to get an official to exempt my bike from the “rack with the seat rule” and allow me to rack from under the brake levers. I have no problem sighting my bike seat as I come out of the water…its normally the tallest one in transition.
I use Blackwell carbon levers that just fit the transition rack bars.
some smaller races I have had issues with my seat being too high and almost impossible to remove.
never tried the brakes though maybe I give a go next ime out
mine too. If the rack is on any sort of a inclin/decline, both wheels are completely off the ground.
I prefer to rack with the saddle but there have been times where the rack is too low and I’ve had to improvise using my flatwing just to get the rear wheel off the ground…always a bit worrying. The racks aren’t always that similar to one another so I’ve just switched racks before. You should let the race director know if you’ve had problems, some of them might do something about it for the next time (like the earlier post in this thread).
I’m also riding a huuuge bike (62-63 cm) custom made Pinarello (I’m 196). I designed a little “hook” to have instead of a saddlebag behind the seatpost… Never had any problems with this, also getting my bike away from the rack much faster than with hanging it on the breaklevers or the front of the seatpost.!
Well, if I stick with my aero extension under the base bar (see my “quick poll” post for info), I’m sure it won’t be long before I show up at a race and can’t rack my bike at all. So, I figure now’s the time to take care of it.
I’ll have to send you an updated pic of my bike when I get the front dialed in. It probably looks alot different than last time you saw it.
BTW, I saw you post about elastic laces. Does that mean you’ve been green-lighted for running?
Steve
Any chance you have a pic?
Steve
same problem…
Dan
www.aiatriathlon.com
That is what I do alot of times at short races where you really don’t need much water. I will rack the bike using the double bottle holder hooks that come off the back seat. Works like a charm and you can even leave water bottle holder on the hooks and they don’t get in the way.
If you ride with an X-Wing hydration system then this method would be out of the question. I never rack by the brakes so I can’t help you there. However I can say that I have never had my bike fall off a rack when using the bottle holder method or when using my saddle.
Me three - although depending on the rack, I don’t need an incline. :slight_smile:
http://www.larsschmidt.dk/filer/balndet%20127.jpg
Here you go, just like that…!
That hook is awesome. What exactly is it made out of? Did you custom fashion the metal or adapt it from something else? Also, how exactly does it attach to the seat railings? Thanks.
Thanks. Very cool.
Looks like it’s just some sort of (aluminum?) strapping with holes in it that you mounted using two zip ties (one through a hole in the strap & around the saddle clamp and the other around the seat rails with the strap passing through the center). Is that accurate?
It doesn’t look super wide. Is it pretty stable when hooked over the transition rack?
Steve
Hi I have the same problem 58 cm Dual seat clearance is 42 inches. I have made a small bracket that will fasten to the seat rails. (My son and I have used these for the past 5 years) cerveloguy a loooooooong time ago made the suggestion (think steel and Meile and kids of steel old) . (Did the resolution run to-day) Cerveloguy after the article in the tri mag, I cannot have enough respect for what your speedy lady races with. You are truly blessed (except for the chillllllie she ate to-day) you obviously treat, and treat her right!!
Sorry any bracket you can fashion that will hook up the seat helps.
Rick
GO EAGLES!!
Cervelo dependent since 2006
and proud of it.
