Race bike on trainer
How many of you use the bike you race on on your trainer…and do you think the trainer has any
effect on the frame of the bike…
no I don’t think there is any ill effect (except the sweat poring onto it).
But I set up my old masterlight (dented toptube and downtube) on my CT with downtube shifters and junk 105 so I don’t have to swap it on and off the trainer.
makes it one less excuse for not riding the CT…
g
I do put my race bike on the trainer and don’t think it has any negative effect.
I use an older tribike on a trainer, but this is because I don’t want to keep trading it back and forth. I would rec. that if you use your tri race bike I would consider maybe using a older, more solid heavier wheel and heavy durable tire for when your using the trainer because it seems to be harder on your back wheel… I go thru tires much faster than similar time on the road so “maybe” there is increased stress on this part of the bike…(unscientific observation only).
i have a guess that this is a bigger issue on the old trainers where you locked the fork in place, ie some strain on the BB.
I use my race bike on my trainer.
i do, although now i’ll prob have to replace my cassette and chain after clocking so many indoor miles on my race bike…i also can see my BB moving and that scares me a bit…hope im not putting too my stress on my frame.
IMHO a trainer DOES have an effect on the bike… When I worked in a retail shop, we would “test” some bikes by riding on trainers after hours… one look at the frame flexing will MAKE you stop riding your race bike on a trainer… Stand behind a trainer when someone is riding a carbon bike and you will see what I mean. Ride rollers instead… they may not provide as had of a workout, but they will improve your ability to ride in a straight line… and im my opinion, most triathletes lack this very important skill…
Rocket
Rocket
Do people actually ride their tri bikes on rollers down in the aerobars?
Good question, JCR. I’d like to know how long it took most people to be good enough on rollers to spin while in the aerobars. I’ve had my rollers for 2 months and still can’t do it. When I try, I’m too squirrely - all over the place.
Carbon is supposed to flex. Its breaking thats the issue. And i haven’t heard of anyone snaping the back of a frame in half on a trainer yet so i’m not worried about it.
There are a lot of people who put out a lot more watts then me on a trainer. I think someone emailed a company and even asked and they said it would be fine.
Grant
I’ve been riding my Dual on the rollers on the aerobars all Winter working on getting lower in front. If you can relax, it’s really no harder than riding a road bike (or the bullhorns) on the rollers. Having said that… I do ride in a doorway. I rarely touch, but I like the piece of mind.
I also question how people say that you can’t get a good workout on the rollers. My rollers (Krietler Poly-Lytes) are every bit as hard as riding the same gear in the flats outdoors. Unless you can spin out a 53/11 without it being hard on the flats (doubtful), you can get a great workout on the rollers. The only things you can’t do well (or, at least I can’t) are standing sprints and very hard intervals. Then again, I don’t do those things in tris, so why do them in training for tris? I’m more of a steady-state effort and long interval guy myself.
Steve
We definitely ride our racing bikes on trainers while its snowy here in the winter. You can certainly train the proper muscles if you use the same setup on the trainer as you use on race day.
As for those that worry about BB flex while on the trainer just consider that, for the same given power output, your frame will flex just as much out on the road. You just don’t have a static point of reference to be able to see it.
I do wonder about the effect on the rear hub bearings. If you have them set so that they are perfect when clamped tightly in the frame I would think they would be too tight when you clamp them in a trainer.
Can anyone weigh in on this?
Dan
www.aiatriathlon.com
I think frame flex is more noticable when on the trainer, but I’m not sure if it’s greater. When you’re on the road, you just don’t really see the flexing because there is no stable source of reference.
Hurt the bike I don’t think so, but I have witnessed the frame flex in carbon bikes, and it is impressive and one of the reasons why I recently purchased a titanium bike.
Hurt the tire definitely. Go get yourself a inexpensive rim with a hard tire to ride on save your good tires for riding outside.
This is true you do have to be careful about having them clamped too tight. Its pretty easy to tell on the computrainer when you get on and you are doing 250 watts and going 12 mph lol.
Grant
I put my Plasma in the trainer. No problems what so ever.
I notice what appears to be flexing. I suspect that a lot of the perceived flexing is actually coming from the tires.
I use my race bike on my computrainer. I do not believe that it has any negative effect on the bike. You can see the frame flex but any half decent bike will be able to stand up to it. I think bikes can and do take more abuse on the road.
rollers are much harder than a trainer, IMO. if someone wants to get psycho about it they can get the killer headwind fan and really put themselves out. me, i’m ready to fall over after 35 minutes, given i cannot space out and loose awareness of the workout, which is much harder than sitting on a trainer.
but in regards to race bike on trainer, many people do it. however, i’m of the opinion that if someone is going to be on a trainer for hours and hours, it is not a bad idea to get a trainer bike (nothing fancy, just something to log the miles on).
