I did my first ramp test at home on my power meter last night. I’ve worked out some ranges for training and a projected pacing window for a 10 mile TT I’m doing next week. My question is what value would I use to log my current power to weight ratio ? Peak power ? MAP ? Average power ? Normalised power ?
I want to enter a value into my training diary to keep a record but wonder what value I should use…
Yes I was actually using your protocol from your website as a starting point (good article by the way) as I’ve used ramp testing traditionally and it’s repeatable. I was just curious as to what value I would use obtained from this test that I would use to obtain power to weight ratio ?
Do you mean what power output would you use, as a marker for your current fitness? I’d suggest recording your MAP, your power to mass ratio (MAP/kg) and also when you do your 10 next week, i’d record your 10mile power as well as 10mile power to mass ratio. I’d use these as your baseline markers.
I’d only suggest using your peak power if sprinting is involved in the events you compete in (e.g. road racing, crits) or possibly for pursuiting as well.
From your test I obtained a MAP of 457 watts so from that and your body scaled suggestions I can work out a rough range to work to for my Xmas TT next week. Now if only I was 70kg and not my 89kg…
I’m looking forward to next week as i find power data review incredibly fascinating. There is just so much to do. What I really need to find is to identify where my LT is but then thats something thats always hotly debated !!!
personally, i don’t think there’s a whole lot of need to identify your LT for coaching/training purposes. However, the scientific definition is usually one of the work rate that elicits a 1 mmol/L increase over exercise baseline level (this would give a lactate of 2.something mmol/L) or the work rate that elicits a fixed lactate of 2.5 mmol/L. Work rate is power in cycling or velocity in running.
If i was in the lab, i’ve used the former measure, while Andy Coggan uses the latter measure. In reality there ain’t gonna be much in it.
Both of these are going to give a power output of ~ 10 - 15 % less than that which can be sustained maximally for ~1-hr.
The ergomo automatically calculates your watts per kilo! Just look on the athlete overview page…
Why would you want to write a training diary when you can run one online via word or something and just refer back to the ErgoRacer data?? Works for me…
