I went to fill my tires for my race in the AM on my 808s (Vittoria tubulars), and I can’t seem to get the valve to open. I have tried repeatedly, and so did my big, burly behomth of a 6’, 155 lb, distance runner of a husband Neither one of us could get it to engage. I’ve raced/ridden on them numerous times in the last month and I haven’t had an issue at all, and the tires were new in May. The extender is Zipp, like the one below:
Is there a trick to getting it open? Can I do it manually somehow? I’d prefer to humiliate myself by asking here now, rather than dragging it shamefacedly to the Gear West guys tomorrow AM prerace and having Kevin laugh at me
ETA: I THINK (although can’t really recall for sure) that the shop guy said he taped the extender when they put the tires on…so I can’t unscrew it, can I? It seems fairly tight in there.)
You can shuv something down the extender to push the valve in and maybe free it up. The way the extender works is it just goes over a regular valve that is left open, so just imagine putting this extender over your training wheel valve. So to deflate the tire you would stick something down the extender (like a small hex wrench) and push the valve down to release the air. Hope this helps.
The “Tape” is just plumbers nylon tape that creates a better seal, you could technicall unscrew the extension but you may have a hard time getting it back on since it will be down inside the carbon rim.
BTW, next time I would suggest using the Tufo extenders since it keeps the valve where you can see and replace it if needed.
Yeah, you can stack them on top of eachother. For my 808s I use two 40mm extenders. For 1080s you may need to add another. They come in 2 or 3 different lengths. I use the plumbers tape all all threads including the valve.
Make sure your tires come with “removable valve cores”
Okay, so I had to use a coat hanger…put I pushed it in good and hard and…nothing. Except now the valve extender is loose and turns. I think I may have broken the seal of the tape or something, b/c if I put my pump on and pump…I can just hear the air whistling out.
Is this something the shop guys can fix in the AM at the race, or am I SOL for a front wheel?
they should be able to get you going, get a good night sleep, get there a little early (bring your spare, they probably have something anyway but just in case) and i am sure you will be fine, have a great race!!
Gear West staff will be able to fix it. Just don’t be there last minute. And don’t be embarassed about an extender problem, you’re in good company.
By the way, there is a “How-To” video on the Zipp web site on how to use their extenders. It’s a very good video and those are very good extenders when you follow the steps outlined in that video.
Use a straightened paper clip to push it to deflate. And yes, it sounds as though the valve is closed. Use the bontrager tubes that have a removable valve. Then with their extender, the valve can be on the very outside so you can access it. A bit more expensive, but well worth it.
Topeak makes a valve extender that you can use to actually unscrew your valve. It has an o-ring so it doesn’t leak and you can open and close the valve on your tube. I found them at REI.
remove valve extender and turn it upside down. re-insert it, press it down hard and turn it counter-clockwise (basically, you need to unscrew the nut, which has somehow closed up). Then re-install the valve extender. This normally works in a pinch.
If that doesn’t work, then you need to quickly get one of those Topeak jobbers.
This is probably the issue (you are trying to pump a closed valve). What I usually do for this is unscrew the extender while applying some side force; again the goal us to unscrew that little nut on the top of the valve. After each attempt, flip the extender around and see if you can now depress the valve (should only take a couple tries).
In the future, crimp the nut with plyers, or add a drop of superglue to keep it from screwing back down.
