I have a plan. I have a beer fridge with a completely empty freezer. I plan on turning said freezer into my kegerator, and by kegerator I mean a 2 tap corny keg system. my only concern is if the corny kegs will dispense while on their side. I thought I’d seen them dispense soda syrup this way but i coudl be wrong. any thoughts?
I don’t think this will work at all. If your Cornelius kegs are like mine, (I use 5 gallon ones for homebrew), there are 2 taps at the top, 1 for CO2 to enter and 1 for the beer to dispense. The dispense tap is connected to a thin stainless steel tube that runs to the bottom of the keg. This way you will get almost all the beer out of the keg. The CO2 puts pressure from the top of the keg and the beer is dispensed from the bottom up. If you put your keg on its side, you will bubble the CO2 directly into the beer (not sure if that would be a problem or not). The real problem is as soon as your keg is half empty, it will be below the level of that stainless steel tube and you won’t be drawing anything. Why not just use the refrigerator portion of your fridge and stand the kegs up the way they are supposed to?
It can be done. You need to bend the stainless tubing on the outlet fitting so the tube hits along the side of the keg, then be sure that side is always down facing. Use a tubing bender to be sure you do not pinch it. You will lose the ability to get the final two to three pints out that way but at that point you can just stand it up and dispense it since you are so close to finishing it, what’s another couple of beers ![]()
Be careful though, you can get blow back into your co2 regulator if the pressure in the keg goes above the regulator pressure and there is beer touching the co2 in poppet valve, which would only happen if the keg is on its side. A fix would be a one way check valve on the co2 in line that would stop that fom happening. Costs about $2 but worth it because sanitizing a regulator is a bitch (I’vedone it a few times over tha past 20 years of brewing)
You will also need a temperature probe power regulator. That’s how you turn the freezer into a cooler. Don’t waste the money on a digital one, get an analog unit, they are more reliable and cost less. I did this for 12 years before I got out of the brewing phase I was in (brewing 200+ galolons a year) and got into triathlon. I brewed the first beer since I started racing IM distance just a few weeks ago for my brothers wedding. Just sampled it while racking it to secondary fermentation. Nice to know I “stuill have it” because it’s tasty!!
Good luck. Let me know if you have any more questions, I have rigged more jockey boxes and kegerators than I can remember at this point.
Dave
I stand corrected. I should have known better. If a guy is going to go through all that trouble to make his own beer (though its not really trouble), what’s to stop him from reengineering the keg dispensing system to better meet his needs!
The wealth of knowledge from ST on obscure topics never ceases to amaze me.
Maybe I misunderstood-
how big is that freezer on your beer fridge? Can it really hold two corny kegs on their sides? I might have to look at my beer fridge…it never occurred to me to put the corny’s upstairs!
Also, how do you plan to regulate the temperature in the freezer? I understand Karma’s idea of a temp. controller, but I’m not sure that would work because the refrigerator and freezer use the same compressor to cool the unit. If you were using the temp controller to override the thermostat to make the freezer a cooler, then that might mess up the temperature in the refrigerator.
I’m not trying to be a hater…I’m a homebrewer too and love to hear what everybody uses to regulate the temps of their brews…
You are right. You can’t do a probe temp regulator on a combination freezer/fridge or it will mess up the fridge part. I used a 21 cubic foot freezer and it would hold 15 gallons fermenting and 30 gallons in kegs along with storage of about 60 bottles of special beers from around the world. I had 12 year old scottish ales and barleywines in there under perfect conditions. When I sold the freezer, I had one hell of a beer tasting party with friends!
Dave
