I did a duathlon for the first time with the watt o meter and was suprised how much less power I was able to make after a short run.
My question is this–people talk about the steep seat tube angle sparting the legs for the run off the bike, does this tend to work the other way where the muscles tired from the first run are de-emphasized more in a steep position? I’m riding a UCI legal position which is quite a bit back from where the typical tri bike is set.
Just curious, I don’t mind sliding it forward if it will help me go faster.
I would definantly slide it forward, i had a similar experience recently, with a more relaxed seat position, i tended to use my hamstrings and other more running specific muscles, moving forward on the seat should isolate your front quads more, medialis and lateralis, as long as the race isnt much over 40k, that should be a big help. Try to ride between 90-100 rpm, you should feel a lot better in the more forward position with more watts. You might lose some aerodynamics, its hard to know without testing both postions in the tunnel, but try two 5min TTs, one in each position and compare the wattage, you should be able to make many more watts in the more forward position.
I would not discount the novelty of the run into ride aspect on your power, it is quite common for athletes to be way low on their rides in duathlons compared to other sessions regardless of position. Duathlon is its own beast and power values after running in a race are one of those features.
