Hi all,
further to my wheel ponderings, I’m now pondering a frame change next year if I decide to go 700 rather than 650 (oh the slippery slope). Last year I had a John Cobb fitting, and went away very happy with how the bike felt, and with a page of measurements so I can put the bike back the way it should be after each trip to a race. It’s been very comfortable since then.
Now, would those measurements be the same on a different bike.
The sort of distances I have seem to me to set my body in the correct position, which should be close to ideal regardless of what you change around it. The measurements that put your skeleton in a set position won’t change, so could I set another bike up the same way.
measurements are:
a, Bottom bracket to top of seat (3.5" from nose)
b, bottom bracket to saddle nose offset
c, nose of seat to center of handlebar
d, nose of seat to center of steering tube
e, nose of seat to center of shifter mount
f, center of front axle to center of shifter mount
g, center of front axle to center of elbow pad
h, width of aerobars
i, width of aerobar pads
of these, the ones that I think should remain the same are a,b,c,e,h,i. the others would vary according to the geometry of the frame and the wheel size.
Reason to ask is, as I live in Borneo, I would have to mail order a frame, build in with the 105 parts off the current bike, but larger wheels, and set it up according to JC’s measurements.
Is this right, or would I be missing something important.
Cheers,
Justin.
