Question about BB. I have a friend who has bought new powercranks and said he would give me his old ones to try, what hell, right? I’ve got nothing to lose. Anyway, the BB is old, and I was wondering if it can be upgraded with an accessory for an external BB without having to get a new/used bike or a new unit. Any help on this? Thanks!
PowerCranks are not compatible with external bearings. All you need to is make sure the BB type is the same as the cranks you have received.
They’re not, does this mean I am SOL unless I get another bike/powercrank?
Just buy a new bottom bracket.
Sounds like you’ll also have to have a Shop / Mechanic do the install as well. And switch back when you want to use your old cranks. Things may get complicated if you have a BB30 though.
OR you may want to learn how to switch out Bottom Brackets yourself- 5-10 minutes and it’s not brain surgery.
I’ve removed my BB before for tune ups on my bike, but I have an '06 Cannondale and do not know if any other BB are compatible with my frames shell other than the external ones.
This is usually not a big deal but your bike shop should be able to tell you what you specifically have to do to make them work on your bike.
Thanks. Looking forward to using them in the offseason
